gigabyte B450 aorus elite rev1.0 bios and ec
    hi ...i need working ec for this model gigabyte mainboard B450 aorus elite rev1.0...extracted main bios and ec are uploaded with this request...ec chipset part nomber is 25L4006E and main bios chipset part nomber is 25U12873F...bios can find easily from giga site but my problem is 512k ec that i cant extract from
    ecfw update for programing the chip.i will send my bios and ec extracted from mainboard and those i got from gigabyte site. i posted this request before but no response i thought may be i posted in wrong directory.thank you for your help.
    Re: gigabyte B450 aorus elite rev1.0 bios and ec
    The mb_utility_ecfwupdate file you posted must be for multiple boards (extract the zip with winrar or 7-zip),there`s 6 different EC updates, none had a unique identifying number of letter to know which one is the right one,all you can do is look at the code and see which one looks the most similar.To me V632 looks the best one.If its no good then youll have to try the other five ,one by one.
      thank you so much for your time and help...i will check it and post the result.
        heloo,
        you solved ?
        thx.
          Originally posted by Aliencomputres View Post
          heloo,
          you solved ?
          thx.
          sorry for late respond....no it doesnt work...cpu cannot be detected...same az before....for the record this happend when user changed power supply of the case for better performance and graphic card upgrade...i checked every thing cpu and ram were ok...new power supply was ok too but mainboard not...so owner decide to buy a new motherboard for himself.
            got an B450 aorus elit v1.0 board for repair.
            with a Ryzen 3 3200g processor
            and i "acccidentally" erased EC bios, lol
            flashed main bios 65e from Gigabye site
            and flashed Soso's ecold dump and it worked!!
            Later on, i decided to run EC Fw Update tool ( see pic)
            and made a backup dump from this working EC bios
            V684.
            hope it helps!
              V684.
              hope it helps!
              thankyou for update and sharing.
                does anyone on this thread have a binary dump of a working bios for this board (b450 aorus elite) I am trying to rewrite it after a corruption using a CH341a editor but it's not accepting the bios gigabyte provides.
                  V684.
                  hope it helps!
                  How to flash bios from gigabyte site?
                    Please, does anyone have .bin dump clean of B450 Aorus Elite v1 bios to use with CH341A flasher.
                    Thank you!
