LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by Maxpower3 View Post
    try patched and test after your remplacement file
    Tried but unfortunately no display, it turns off after few seconds...
      @Ariu
      It is normal to turn on and off automatically up to five times during the first boot, please wait...
        if i compare the patched file with the dump they are totally different or is that normal??
          Originally posted by onizzbox View Post
          @Ariu
          i know that is normal but just turns off an i muss push the power button to turn it on again...
            In this case it is not normal, we have a problem...
            Do a test... Keep the case lid closed during the next tests. Some models have (violation sensor).
              i tested but same...
                Try
                  Try
                  no diplay
                    no diplay
                    l460 is a i7 vpro if that is important...
                      Attach the working dump with password.
                        this dump is working...
                          It's not a problem with the BIOS, for this model the patch doesn't work in the traditional way.
                            @Ariu
                            Wait, I'll check...
                              @Ariu
                              Wait, I'll check...
                              @onizzbox
                              the dump works fine i flashed it again and works, the strange thing is that i'm able to enter bios setup without typing a password , just enter and the bios pops up, in the bios settings is supervisor password enabled (grey colour) and i cannot enter or make any changes there...
                              how do u explain that?
                                @Ariu
                                Wait, I'll check...
                                This one...
                                  This one...
                                  @Ariu
                                  Apparently you are recording the wrong chip, check the UC8M1, UC8M2 chips.
                                    This one...
                                    Attach chips, UC8M1 and UC8M2
                                      @Ariu
                                      The uc8m2 chip is the original bios i didn't rewrite or changed it, I only reprogrammed the uc8m1 chip with the previous dump and works, the original bios file of uc8m1 is corrupted, or does it make sense to attach my own original corrupted backup of uc8m1 chip , perhaps can anyone repair my backup??
                                        Exactly! I need the uc8m2 chip reading!
                                          Unlocking is performed by the uc8m2 chip, after unlocking, return the original file.
