View Single Post
Old 08-01-2019, 12:40 PM   #14
dicky96
dicky96's Avatar
City & State: Sunny Gran Canaria
My Country: Spain
Line Voltage: 220V 50Hz
I'm a: Professional Tech
Default Re: Philips 234e problem
Quote:
Originally Posted by R_J View Post
What does'nt make sense about the U705 circuit? Pin 5 (LX) is the output which connects to a coil and then to Q492 fet, Q492 is likely a switch that turns off part of the circuit during standby.
What didn't make sense is I thought source or drain of Q492 was directly connected to U705 Pin 5 LX..... until I was driving home from the workshop and it suddenly occurred to me that Q492 was probably a switch (like you also think) and was not connected directly to U705 but via the inductor instead. Then it did make sense Hence post +11
I'll check the other voltages like you suggest. Thanks for your continued help
Rich
dicky96 is offline   Reply With Quote
