List of pin compatible Laptop ICs
This is a sticky topic.
    Re: IC equivalent
    here is a datasheet .. https://www.datasheetq.com/RTD2136R-doc-Realtek
      Re: List of pin compatible Laptop ICs
      ok tanks,i have it ,i need equivalent for this
        I found a chip as PUM1 with marking 4B=4J on HP LA-E841P. But on another same model motherboard i found G5616B as the memory controller. Is that both are same? If it same, Does anyone know what is the number of 4B=4J chip and also i need Datasheet for it. There is some difficulties to get datasheet for G5616B and can get G5616A. but both are different.
          https://www.google.gr/search?q=richt...e-gws-wiz-serp
            Thanks bro. Now i got the correct information of these both chips and its looking both are same.
            So anyone can Use These both chips as compatible for DDR4 PWM Buck converter
            G5616B = RT8207P ( with marking 4B=4J )
              hi all
              i have mb dell Dell Inspiron 15-3542 Wistron Cedar MB 13269-1 FX3MC
              i found 2 ic tps First (tps51225) Second ( tps 51716)
              this ic tps51225 is hot which alternatives for it and where is the ic power
                Originally posted by mmaewbsoft View Post
                hi all
                This tps51225 is Step down controller for 3V 5V and TPS51716 for DDR3 power supply. I had the similar issue on a same board. I checked pin no.3 for VReg3 was low and i just removed tps51225 and checked that pin again it was low impedance. I inject 0.8V to that pin and i noticed SIO getting hot. I replaced SIO and the problem was gone.
                  You mean replace This tps51225 is Step down controller for 3V 5V with new one
                    I replaced SIO and the problem was gone U said where is it please
                      you mean super input and outpt
                        Yes. Its NUVOTON NPCE285PA0DX i have replaced. But you have to check it before you replace. I didn't replaced TPS51225 ic and i replaced NUVOTON SIO chip only.
                          asus n550jv rev 2.0 it8586 and it8585
                          today i didn't find it8585 so i decided to replace it with it8586 and its work after programming . the motherboard is asus n550jv rev 2.0 .
                          i wanted to share this information with you guys .
                            Thinks
                              does anyone know compatibility with
                              JC-FH ic
                                JC-FH ic
                                No idea what JC-FH is. Do you mean JC=
                                  you can't advise a replacement for sy8032abc or what laptop it might be in
                                    FK*** SY8032ABC LA-B102P
                                    I don`t know if there`s an equivalent
                                      tps51225=rt6575=BQ727b=<3F=1D 3F=EA 3F=FJ 3F=fk>
                                        isl95831 same type plz?
                                          Hi guys,
                                          Is there any other is compatible with UP9002P I have many various IC's but none with this code.
                                          Warm Regards
                                          Paul
