AMITSESetup Decryptor
    Re: AMITSESetup Decryptor
    Originally posted by BootLoader1 View Post
    Working, working, but I forgot about this case. Now fixed and working well.
    It's still not perfect, it still has the problem...
      Thanks for your share.
      Become a Badcaps supporter
      Thanks to all supporters.
        What problem ?
          What problem ?
          I will make a new video!
            What problem ?
            This is the new algorithm, mistakenly known as CHA-1
            Can you add it?
            Hash:
            5BC1B6D211256CFCC78F22ED7D43D838
            33518E5AE9B0443A9F84FA5B556FB0BF
            0BF96603C1B71CCC7716D2A92D3D88D0
            E3633EF7998AF41D4FB1AA4405D8606B
            Master Password: DrfJik
            D - DELTA ( UPPERCASE )
            r - romeo ( lowercase )
            f - foxtrot ( lowercase )
            J - JULIETT ( UPPERCASE )
            i - india ( lowercase )
            k - kilo ( lowercase )
            In Laptop, type the password and press <Enter>.
            (copied to clipboard)
            Press any key to exit . . .
              I wrote software only for old algo. I don't have the file with new algo. Can you share ?
                Can you add it?
                Hash:
                look!
                  This is example only. In order to get algo I need bios file with this algo inside. I don't have it.
                    Can you add it?
                    Hash:
                    it looks very complicated still that, a real chaos
                      thanks for bring the python and the windows exe !!
                      I have a asrock mb ami with stored password, both tools are unable to find password.
                      If I look into uefi tool I can find (multiple)
                      4E5641523800FFFFFF820B414D495453
                      4553657475
                      (amitsesetup)
                      The one with data in it starts at 0020 and 01 is at 0030
                      I understand it should start at 0040
                      And my length is just over 1 line in uefitool
                      On the main board I see a other small windbound chip, maybe I am unlucky and is it storted there
                      any tips are welcome
                      thx
                        4553657475
                        (amitsesetup)
                        thx
                        Post your dump.
                          In my opinion this is just a customized bios with a hard-coded password, so every time you use [Load Default Values] option in Setup/BIOS, it sets this "DrfJik" password on the ToughBook.
                          If you search for the hex hash of that "DrfJik" password you will find a 3 matches, a couple of them in the UEFI AMITSESetup variable and the other match in the DXE AMITSE module (the module with the hard-coded password and with the code that hashes the password).
                          This is the Panasonic ToughBook CF-H2 MK1 bios dump:
                          https://www.badcaps.net/forum/showpo...78&postcount=5
                            work nice on ASUS X407UBR REV 2.0.. Thanks bro..
                              Asus VivoBook X512D bios password decrypt help!!!
                                try and feedback
                                  Originally posted by Bsolution View Post
                                  try and feedback
                                  @Bsolution
                                  I think he wants to know how to decode the password.
                                    @Bsolution
                                    i know how, but no password
                                      @FlorinGruia
                                      To me it seems like the password is SHA256 hashed (AMITSESetup variable contains a block of 32bytes+8bytes set to 00h's), if so, password can not be recovered easily.
                                      So you will need to use a SPI programmer to dump bios, clean this original bios file and then program the new clean bios.
                                        can you help me, please, and decrypt BIOS password for my Panasonic CF-53.
                                        Encrypted hash:
                                        55c6b65511646c4bc7a722167d70d8da33278e4fe99344649f25fab95551b0c10beb6690c11c1c2e7716d2a92d3d88d0e3633ef7998af41d4fb1aa4405d8606b
                                        Thanks in advance
                                          @BootLoader1
                                          Very cool, but it doesn't work!!
                                          Needs repairs...
                                          Can you share this tool here
                                          Thank you sir
