My HP EliteBook 865 G9 notebook was accidentally encrypted and could not enter the BIOS. It is relatively new. I extracted the data of the front and back memory of the motherboard: 6050A3334301-MB-AX1. I hope someone can help me.
HP EliteBook 865 G9 - BIOS issue decrypt
Re: HP EliteBook 865 G9 - BIOS issue decrypt
Originally posted by haopcxg View PostMy HP EliteBook 865 G9 notebook was accidentally encrypted and could not enter the BIOS. It is relatively new. I extracted the data of the front and back memory of the motherboard: 6050A3334301-MB-AX1. I hope someone can help me.
it will enter in MPM mode, press F10 and you have a tab under "Main" named " set machine unique data" and you'll find all data on stickers of back of the bottom cover. to exit MPM mode use BCU 4.0 under windows or restart laptop how many times counter shows.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Originally posted by haopcxg View PostThe HP screen is very slow after powering on, a few minutes.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by volinakis View Posttry clean ME or read again chipset with bios unlocked and post it here. i will try to clean ME for you. Did you set all data for your laptop? do you have any warnings on start up?
Originally posted by haopcxg View PostSeveral red flagsAttached Files
Become a Badcaps supporter
Thanks to all supporters.
Originally posted by hoaca388 View PostAMD system has no ME region, try this file and feedback
Originally posted by haopcxg View PostClear the IC and write the firmware. The computer does not respond when it is turned on. The caps lelock and numlk indicators flash 6 times, and the charging indicator flashes; When the machine is restarted after forced shutdown, the power indicator lights up once, the caps lelock and numlk indicator lights up for a long time, the power indicator lights up twice, and the charging indicator lights up; Then press the start button to cycle.
Originally posted by haopcxg View PostTurn on the black screen, the fan runs wildly, and HP icon and red letter appear after 1 minute. How to clean ME; There is only red ink and no warning when the machine is turned on. It only needs to read the IC content next to the memory, and it still needs 2 IC contents.Last edited by volinakis; 01-19-2023, 02:52 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
After rewriting the firmware, you can start the computer. Now the problem is that the HP screen appears for too long, and all the contents are filled in. It is observed that the keyboard light needs to light up twice before the HP screen appears after pressing the power key. The first time is that the caps lock and numlk flash six times, and the second time is that the HP screen appears.
Originally posted by volinakis View Postsince you can enter in bios setup it means you have no password. Load factory defaults (doooh! it is obvious!) and "change admin password" will disappear. Set machine data as I told you, exit MPM mode as I told you and "red ink" will disappear. I see from your photo you didn't set correctly data, Product Name is HP EliteBook 865 G9 Notebook PC, expand "show Advanced..." and don't blur it because ALL DMI are in bios content you post it here.
Originally posted by haopcxg View PostI checked my BIOS file and found that it was the engineering BIOS (U82 Ver. 80.13.00), not the official BIOS (U82 Ver. 01.03.01), so there was a startup exception. I couldn't upgrade the BIOS (prompt: BIOS update did not occur because the system administrator has locked the BIOS version). I uploaded the latest official BIOSAttached Files
Originally posted by miansh621 View Postfeedback
Back up the files that can't be turned on. Is it different from the original file?Attached Files
HP EliteBook 865 16 inch G9
