Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
    Re: Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
    nothing happened with last one...same thing. the ram are onboard.
    i will write for x555LD rev. 3.3 that worked with a few bugs .
    thanks you
      thank you
        Originally posted by kiraro View Post
        hello ,
        i share three bios for asus main board x555ld rev 2.0 and rev 3.3 and rev 3.6.
        hope that help someone .
        thanks
          thanks
            thanks
              thank you
                hello ,
                thanks man
                  kiraro thanks
                  BACKUP_X55LD_REV_3.3_ORIGIN.BIN
                    Originally posted by alvyn View Post
                    how to flash or setup board X555DL v3.6 to v3.3 (downgrade) my board HDD v3.6 broken and i want used board HDD v3.3.
                    Thank's
                    Hi i need make this, somebody can say like make it?
                      Originally posted by danon2
                      im looking for asus x555ld rev 3.3 schematic it dont see my hard disc. the board view i have but i need schematics with details of parcels on the board
                      HDD not showing is comment fault you have to replace the Hard Drive connector BOARD
                        you send bios problem 3 bios start ok no nvidia graphic..
                        Orginal Asus x555LD V3.3 ok no problem .. orginal bios nvidia display ok ..
                          hello ,
                          thanks
                            Thanks a lot.
                              thanks
                                x555ld rev 3.3
                                nvdia 940m - n16s-gt-s-a2 bios ?
                                  hello ,
                                  Hope that help someone .
                                  thx
                                  OKBALORD
                                    Thanks you, working OK!!!
                                    hello ,
                                      hello ,
                                      thanks bro
                                        board number: x555ld rev:3.3
                                        case code: k555ln
                                        gpu :840m
                                        cpu i5*****u
                                        perfect bios
                                          really Thank you it saved my day god bless you
