Sony ADP-200ER Ps4 Power Supply
  • hugonoizz
    • Nov 2021
    • 3
    • Italy
    Hello
    I am new to this forum and kind of new to board repair as general, I have learned how to change stuff using soldering iron and hot air but I am still lacking good troubleshooting skills, so this brought me here…
    I have a ps4 bought from ebay with the intention to repair (probably has already been to numerous technician before me), it has been dropped at some point so it has broken plastic everywhere…
    I'm any case it has a well known fault, when you press the power it starts but after less then 0.5 seconds it power itself off.
    So I took the power supply apart to check the condition and to my surprise I saw it was already taken apart before because you can see fresh solder near the first fuse and also I think near the pfc choke (I think is that)
    Anyway this is what I checked:
    - 4volt rail OK
    - Fuses Ok
    - No short (for the best of my knowledge)
    - Shorting the sense pin -> 12v coming up for about 0.1 seconds but slowly decrease and then no 4v
    - Every time I start the 12v rail I have to remove the power to try again
    I watched some guy's video on YouTube about how this power supply works and It was very illuminating so I thought maybe it's the pfc choke (the guys reference it with that name) so I took it out and found that it has broken plastic and it shows a short (see attachments)
    I would like to find a replacement for that anyway
    It's like a big coil of wire right?
    Also the main capacitor is around 130uf, can that be the problem?
    I already order another power supply from china but I would like to repair this one just to learn
    Ps sorry any verbal or vocabulary error, I am Italian, English is tricky to me
    • 30978
    Re: Sony ADP-200ER Ps4 Power Supply
    the unductor (pfc choke)
    is just a coil, it's supposed to look like a short.
    put it in your component tester and check the inductance.
    • hugonoizz
      • Nov 2021
      • 3
      • Italy
      Not sure if I put it correctly
      If I giggle it around I read 0.25 mH same resistance
        • 30978
        i dont know what it should read, but i expect to see a much higher reading!
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
