DVR camera recorder switching power supply capacitor failure really
    These cheap non brand capacitors at it again
    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
    Well at least I have the cameras back on line I to try the hard drive tomorrow and see if it got damaged as well
    One note the cameras are on a medical grade switching power supply by themselves because when I first put in this system I continuously had switching power supply failure on the cameras and had to replace several cameras and switching power supply of because of switching power supply failure
    All I can say good about this DVR camera recorder and switching power supply is that this has lasted about 6 years so I guess I really should not complain to much about it
    I will post some pictures of the switching power supply before I put heat shrink tubing on it to keep it together and after I try the hard drive to see if it still work
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: DVR camera recorder switching power supply capacitor failure really
    6 years = 52,594.92 Hours, I would say that cap had a full life
      6 years POH or 6 years sitting in the closet?
        Yeah it even keeps trying to restart which is really weird even with the capacitors being at over 40 ohm ESR reading because the power supply light pulsing very quickly on and off on the DVR camera recorder
        9 PC LCD Monitor
        1 Dell Mother Board
          Well is has been running scene last night and so far so good I am supposedly going on vacation next week but not this Monday but next Monday and then I will test the hard drive and if still good will put it all back together and call it repaired
          9 PC LCD Monitor
          1 Dell Mother Board
