Asus X555 no sound
    Asus X555 no sound
    Hello
    So i have a X555 with no audio device in the device manager do you know where is the audio chip on this board ?
    And what i need to check ?
    Re: Asus X555 no sound
    without board photo?
    wait a while and i will get my crystal ball and tell u exactly what chip it is and where it is
      It could be connection problem. There is extra module that attaches to motherboard. On that module is sound chip. Could be faulty connection, simple clean could fix it.
      I had no sound problem, and cleaning fixed it.
        It is the connection contacts of the disk board, it has to be replaced
            i cleaned contacts, reflowed the audio IC, replaced the audio IC .. and after that i replaced the entire sub-board , the audio is still missing... i think that can be something related to chipset/cpu (sometimes) because the 2 connectors are solid (i've also reworked all the connector pins on the mainboard side .. and looks good at the microscope..the other connector is a brand new.)
            the strange thing is that there are no issues with SSD... CARD READERD... USB PORTS .. that are also placed after this sub-board.
            here some other infos: https://www.badcaps.net/forum/showth...52#post1209352
            and also on this youtube video they solved adding an USB audio card and an amplifier: https://www.youtube.com/watch?v=joOtn6vKZkY
