Panasonic CF-54 Bios Password
    Re: Panasonic CF-54 Bios Password
    hi friends
    can somebody reset bios pass in CF-54?
    thanks
      Originally posted by slaw1971 View Post
      hi friends
      thanks
      Try
        Originally posted by onizzbox View Post
        try
        work - thanks bro
          work - thanks bro
          Excellent! enjoy the laptop
            NEXT QUESTION - Can I recover HDD pass from bios ?
              @slaw1971
              It's a lot more simple if you just replace the HDD.
              There's a slight possibility to Secure Erase the HDD, as some models use a fixed HDD master password (HDD Master Password + HDD User Password), if that HDD master password is recovered from the BIOS code then you can use an HDD utility and use that 32-byte password to either unlock it or Secure Erase it depending on the HDD configuration when the password was initially set... but it will take time.
                Greetings from Germany and a happy new year 2022. Got a hold of some CF-54 MK3 laptops. Can install windows but with no access to the Bios. Got the .rom file with help of badcaps.net while reading your advise. It would be great if someone can help and I wonder what "flash" the bios chip meant. Do I have to get a programer device or can I boot from USB stick to flash the new bios rom ? Please, excuse my bad english.
                    Hi, could someone kindly remove the password for me?
                    Thanks!
                    Have a great new year!
                      Thanks!
                      try..
                        Originally posted by peste View Post
                        try..
                        Worked perfectly!
                        Thank you so much!
                          Please could i have password removed ...cf-54
                            Originally posted by shouldube View Post
                            please could i have password removed ...cf-54
                            Become a Badcaps supporter
                            Thanks to all supporters.
                              It means writing information (after modifying, fixing errors) back into the bios chip. You need a programmer device.
                                hoaca388
                                Thanks will try later....
                                  @hoaca388
                                  many thanks to you. I understood now. Got a CH341 programmer. Wish there was a solution without dismantling the whole Notebook ( big problem is the keyboard ). Keep the forum updated from time to time. Have a very nice day, lads.
                                    @hoaca388
                                    https://www.youtube.com/watch?v=3o3qSWCIl1c
                                      CF-54 LOCKED Problem
                                      Thank you
                                        Thank you
                                        Try it yourself with a hex editor,compare the locked and unlocked bios at posts #111 and #112 .Fill in the AMITSE area
                                          CF-NX2 password , help
