Unconfigured Static HTML Module
Static HTML Module Content
philips 32pfl5507k/12
    Hi, for philips i need service manual.
    I have problem with power supplay DPS-98EP A
    I change fuse and TK13A65U. But not have voltage 12V only 3.3V.
    Re: philips 32pfl5507k/12
    Have a look at
    https://english.electronica-pt.com/e...=32PFL5507K/12
      I already found it. i have ERROR CODES - LED BLINKING CODES.
      4s pause and 3 fast flashing led blinking. I can't find this error.
        Why do you need error codes if you know the problem?
          when connected to the power supply, red led blinking. (4s pause and 3 fast flashing led)
          Voltage is only 3.3V.
            Where is TK13A65U in the circuit? is it in the standby, pfc or main circuit?
            Usually when a mosfet like this shorts it opens the source resistor and can damage the drive ic as well.
              i can't find it in the service manual.
                The service manual does not have the dps-98ep schematic. That does look like the main mosfet that drives the main transformer. There is a resistor R611 0.24Ω (mosfet source) located beside that heatsink, check that it is not open, I expect that it is open. If R611 is open, check R610 as well, it connects the mosfet source to ic601'a CS pin.
                  I marked it wrong, TK13A65U is located on the second aluminum plate.
                    What is its board location number? that looks to be a Diode (D120)?
                    Do you have any voltage across C700A or C120A? (I'm not sure of the numbers).
                    If it was indeed a mosfet I suspect it is used to switch a voltage
                      No voltage on c120 and mosfet.
                      The problem is on the primary of the transformer
                      IC 601 may not work. How can I check the operation of the transformer.
                        Check R611 0.24 resistor and see if it is open What is the number on Q601 AND IC601?
                          R611 is good-closed, Q601 is good, ic601 2QS02G
                            Do you have vcc voltage (20v) on pin7 of ic601? be careful not to short the ic pins. There is a resistor connected to pin7, check the voltage there instead of on the ic.
                            I suspect there is no vcc and the supply for the vcc comes from the standby circuit.
                            I am starting to think there is no power on signal from the main board. I suspect PC903 is the optocoupler that turns on the power supply
                            CN4 pin 2 standby should be the power supply on. With CN4 disconnected from the main board, connect pin 1 (3.3v) to pin 2 (standby) and see if you get your 12 volts.
                              ic601 pin7 no VCC
                              CN4 PIN5 no VCC 12V
                              Power in pin2 is 3V mainboard is work.
                                ic601 pin7 no VCC
                                CN4 PIN5 no VCC 12V
                                Does ic601 pin 7 connect to J17 and then to J9?
                                How do you know the main board is working and sending the power ON signal?
                                  when connect CN4 on main board in pin 2 have 3v vcc.
                                  and dont have 12v. I thinks is problem in power board.
                                    Does the voltage on pin2 change when you press the power button?
                                    CN4 pin 1 is the standby 3.3 volts that supplies the main board, CN4 pin 2 turns the power supply on and off.
                                      When I connect the power cable to 220v only red led blinking.
                                      The main board works but reports an error.
                                      Voltage failure is possible.
                                        Here it is listed under layer 1
