macbook air A1932 stuck 5v and DFU mode
    hi all,
    i recieved dead macbook air a1932.. checked with usb amp meter only 5v 0.3A
    checked with apple configurator 2 shows DFU mode..try to revive but error 21. try to restore error 9 and now only show recovery instead of DFU in apple configurator 2..
    can someone help?
    thanks in advanced
    Re: macbook air A1932 stuck 5v and DFU mode
    Hi
    Error 9 usually occurs if there is a "block" somewhere stopping it from connecting with Apple's update server. The best bet is an external recovery.
    (1) Download a MacOS from the internet; (2) Make a USB drive bootable; (3) add the MacOS to the bootable USB drive; (4) boot the make using the bootable drive and recover from there.
    All data will the lost though.
    I hope this helps.
      OP is talking about T2 DFU recovery not Internet Recovery.
        Originally posted by kingskie View Post
        hi all,
        can someone help?
        thanks in advanced
        You need fast internet.
        Error like poor wifi
        2nd :update latest ibridge then check what happened.
          1. already using fast internet but still got error 9 when revive
          2. already using bridge os 5.5-18P4759a_Restore.ipsw (this is for mac os 11.5 but my imac mac os is 11.6..is it a problem?)
            what i want to know now is why it is stuck on recovery instead of dfu because the first time i connect it showed DFU in apple configurator. so now how i change the recovery to dfu mode...can someone help?
              Hi Did you resolve ?
                not yet bro, do you have the same problem?
                  dead t2?
                  hows the esd diodes on data lines?
                  there is a reason it was in dfu mode - you do not try to restore until you check wth is causing it.
                    Originally posted by reassor View Post
                    dead t2?
                    still connected to T2 but in recovery mode, not DFU mode...before it can connect with DFU mode but after error when revive than it became stuck in recovery mode in apple configurator
