Re: Vestel 17IPS20 R6
D214 will not have 240V on it. You need to use hot ground. Connect your black meter lead to the negative leg of C105 carefully and make certain it does not touch anything else. Then connect your red meter led to D214 and measure again.
You say you have the 12V on CN4. Do you also have +5V at CN4, Pin 9 and if not is Q212 transistor soldered on the power supply?
It would be interesting to know what all the pin voltages are for CN4
__________________
