Re: Need tips in fixing APC 1500VA UPS having buzzing noise
The title says 220vac, you're looking for 250vac. The capacitance is fine.
It's -only- a 12% difference in voltage, and for a trial to see if the noise stops, it's worth it. I would not leave it in place permanently.
Sealed caps like these are generally fine for a long time on the shelf. I would apply voltage slowly to make sure it is stable. A lamp in series with the power line. Or, try just feeding the cap through a lamp externally by itself, before installation. That would be a safer way, in case it decides to go *bang*!
If the lamp goes bright and stays that way, the cap is shorted.
Caution is advised.
T
__________________
veritas odium parit
