42LM670TZA , picture freezing , then powers off , or hanging on LG logo .
    Hi all
    Issue seems to be slightly tap sensitive , although that might be a complete coincidence .
    Main board problem none the less .
    Can anyone advise .
    I'm leaning toward re-balling the main BGA processor chip .
    Have the correct stencil in stock , therefore must have re-balled one of these chips in the distant past .
    Re: 42LM670TZA , picture freezing , then powers off , or hanging on LG logo .
    All signs point to BGA, I have one of these boards from a 42LM6400, after reflowing the main chip it lasted for 2 years, then further reflow attempts failed to make the TV last even 1 minute powered on.
    But the TV should not freeze, it should power off immediately or not even get out of standby when it's the main chip.
      Thanks for the input .
      I don't tend to re - flow any more , as it doesn't seem to be reliable .
      Will re - ball & report back
        On removal & inspection of BGA , may have worked out issue .
        part of track , which looks to be a through hole point seems to have been exposed , by heat from the a capacitor that sits directly under it .
        Could try some solder mask to insulate point then fit chip back .
        Although it looks like it from picture it's not a pad .
          Re-ball seems to have gone really well , & solder mask to took exposed track .
            Well i'm genuinely surprised .
            Set powers & now working on a test .
            Lets see how it behaves , or not a the case may be .
              Nice job on the reballing process, hope it fixes it.
                Thanks again
                  Reballed a Vizio a couple years ago. Still working in the living room.
                    Nice one, yes re-balling rather than re-flowing seems to be the way to go for me .
                    Have been experimenting for a few years now & have quite a reliable technique with the equipment i use .
                    Many re-balling videos on You Tube .
                      I think leaded solder is superior to the brittle unleaded. Military still uses leaded solder for reliability.
                        Most definitely .
                        Aviation also , & quite possibly medical equipment .
                        More work for us i suppose
