hi . i have acer aspire E5-575 zaa2... . aptop does not turn on 19 v is ok. 3.3 v comes on the power button and the battery charge light turns on but does not turn on. I tried the bios I found on this forum but it does not work, do you have any idea what I can measure? And can i help mee .. this is shcematic
neeed help plz aspire E5-575 zaa2
Re: neeed help plz
@arber1232, make your posts more meaningful by giving as much information as possible. What have you done to solve??What measurements you did?? With no such information, you cant really expect advice from others. Start with Page 43 of schematic where a nicely laid out power sequence is given. Check what you are missing.Next check page 44 .
Re: neeed help plz aspire E5-575 zaa2
if i understand you then i'm telling you. I have an Acer laptop as I said above. the problem lies because it does not turn on. when I connect it to the laptop charger it turns on the charging light but I try to turn it on but it does not turn on .... I measured on the board that 19v is present .. The power button has 3.2v and the button is OK. I do not have 3.3v in the bios but when I press the power button then I have 3.3 in the bios ... I tried to program the bios but no change. . In ENE i have 3.3 volts. i do not have short in board.
Remove rtc cell and battery and power plug
In cold state, press power button for 30 sec and release.
Put rtc cell back and power adapter plug in only.try to turn on.
Then put battery back and turn on.
If above fails check voltage on rtc cell and check rsmrst# signal and nbswon# signal
Lastly for your information bios gets 3.3v when power button pressed onlyLast edited by stingerchamp; 11-25-2020, 06:56 AM.
It is a active on low signal.
First verify at CLR you have 19volt
Verify all rails are present ,+5,+3.3
Check following signals and verify when you press power button how they react
1- nbswon#
2 - rsmrst#
3- pltrst#
4- hwpg
5- dnbswon#
If you are unable to find it
Try going in cold check way
Without any power check all big coils impedance all should be above 300 ohm except core and vccio.
coil are not 300 0hm. were somewhere at 0.17 ohm .. i have 5 v +3.3 v. nbswon # is ok i have 3.2 volts and when i press power button change voltage ie changes according to the button ... rsmrst # is present an i have 3.4 v and not change whwn i press power button. pltrst # i find in ENE but is 0 v ..and not change when i pres power button .. hwpg is present in tps51225 in pin 7 ,, 3.0 v and in ENE is zero in pin 22 .. dnbswon # is 3,4 v but not change when i press power button
See attached.
Meter in DC volts setting.
Red meter probe to pin # 27. Black meter probe to ground.
Measure the voltage to ground @ pin #27 with the power switch open on the keyboard.
What is the voltage ?
Then press the power switch on the keyboard.
