LG 34UC87C-B X3 Firmware Dumps all EEPROMS
    Don't know if this helps anyone but have just dumped all firmware for the LG 34UC87C-B, moreover has anyone already dumped the firmware for this wide monitor and if so can they check if its valid, the one i'm working on has no standby but all checkable components check out okay.
    Have zipped and uploaded all three pieces of firmware.
    PCB = EAX65923705 Rev 1.0
    IC205 MX25L8006E
    IC901 25X40CL
    IC102 24C02RP
    If not i hope it may help someone.
    Re: LG 34UC87C-B X3 Firmware Dumps all EEPROMS
    IC205 MX25L8006E
    IC901 25X40CL
    IC102 24C02RP
    Quick question does the Firmware that is linked in that Post (for the 34UC97C-B) also work on the
    34UC87C-B or does it need a specific one (looking for IC205 FW)?
    Thanks!
      Re: Eeprom dump thread!
      Hello. Need firmware for LG 34UC87C-B.
      Found some on post https://www.badcaps.net/forum/showpo...&postcount=731
      but archive have a name ""LG 34UC97C-B Curved Monitor"" and it confusing
      Will appritiate any help with searching firmware for this monitor. Thanks.
        In case someone is looking for a firmware for the LG 34UC87C-B which is bricked (no standby at all, appears completely dead), here is a dump from a know working one for IC205, which usually causes this behavior.
        PCB = LM43A | 34UC97C | EAX65923705 Rev 1.0
        IC205 MX25L8006E
        Other EEPROM ICs on board:
        • IC901 25X40CL
        • IC102 24C02RP
        Hope this helps someone!
        Last edited by omladinacm; 01-29-2022, 01:25 PM. Reason: Forgot to upload the file :)
          IC205 MX25L8006E
          • IC901 25X40CL
          • IC102 24C02RP
          Thanks for this. It helped me fix a monitor.
            Thank you omladinacm for providing the EEPROM.
            I flashed the IC205 of my LG 34UC87-B (pay attention: not 34UC87*C*-B) and it's working again. The only downside is that now Thunderbolt is gone (as far as I known that's the only difference between 34UC87C-B and 34UC87-B)...
            Not a big deal, as I'm not a Mac user and do not need the Thunderbolt - but of 'cause it also would be nice to get back to "original" condition. I'm afraid no one has a dump for 34UC87-B?
            Regards
            ZwoCa
              Was not able to fix my screen, but here the dump from my 34UC87-B.
              IC205 if someone needs it.
                IC205 MX25L8006E
                • IC901 25X40CL
                • IC102 24C02RP
                Helped me recover my monitor. Re-flashed via ICSP using XGecu T56. Many thanks.
