Panasonic TX-32LZD80 backlight no picture (fixed)
    Just picked this up, very local to me. Fault was originally described as no picture and I was about to diagnose a bad inverter until I saw this TV does have a backlight, it's just incredibly dark because it's an IPS panel (very high contrast ratio, but also lower brightness.) I might try increasing the current control on the inverter board to see if the brightness will go up a bit more.
    Found the t-con fuse to be blown. Replace that and it worked.
    Wish I could make it more glamorous but hard to go wrong with a 32 inch Full HD Panasonic like this, they're very well built. 2008 series. Picture is no where near as good as my PZ80 plasma though! Panel is a Panasonic too; IPS Alpha tech.
    Re: Panasonic TX-32LZD80 backlight no picture (fixed)
    Hi Tom
    I've got a the exact same model of TV as this and it has the exact same problem. Can you tell me where the T-Con fuse you talk about is located ?
    Many thanks
    Mark
      It's right near the LVDS connector, little black thing. No photos of it, sorry. But it is obvious.
        another easy fix, saved from the landfill as well. I wish i could find more sets to repair not much around at the minute.
          This was about 6 months ago and it was fixed for a friend who found it on Gumtree like this
            yes just saw that now haha but hey its fixed and saved i guess.
              Still going strong though. Only thing I'm not a fan of is the dim image, OK in a dark room like his though.
                no i like nice bright clear images my self to be honest is this how these tx-32lzd80 are designed then?
                  Yep, seen a couple others looking the same so figure it's just how they are made. Have not tried to adjust it yet.
                    im sure you will when you get another project to work on.
                      Hi guys where did you purchase the replacement fuse as I have the same set with same problem.
                      Thanks in advance.
                      @safesurfer65 if you still need a pic I can upload one for you.
                        CPC stock them. Is there a rating, e.g. 1.3A 32V(T) printed next to the fuse? Or alternatively, a letter on the fuse?
                          Yes Tom, it's 24v / 1.6A. PN or txt on the comp body is I62 NCC hard to make our as it's so small , 1206 package I think.
                          Thanks for the reply,
                          Stephen
                            I think I ended up using a 1.5A fuse
                            http://cpc.farnell.com/multicomp/mc1...-5a/dp/FF02271
                            Min order with CPC is £5 now so you may have to add some solder wick or other things to the order.
                              Thanks so much for the quick reply, I'll get this ordered and changed. Can't thank you enough, will post results when complete.
                                [UPDATE FIXED]
                                Well fuses arrived replaced and all working perfect.
                                T-CON - 19100096 MDK 336V-0
                                Great info thanks.
                                Pics below >>
                                  Originally posted by StephenU View Post
                                  [UPDATE FIXED]
                                  Great info thanks.
                                  Pics below >>
                                  its nice when its a cheap fix and it works 100% fine again.
                                    It sure is that vinceroger69. Now onto the next!
                                      Thats how i started too, fixed one then thought this could make a good hobby so now pick up free ones from freecycle gumtree etc to practice repairs one. I also done a few laptop repairs now once you get the electronics bug its hard to stop although theres a lot to learn good job for sites like this and google also some good youtube videos on repairs/testing tips etc.
                                        Amazing!!!! I have a degree in Physics but no experience in tv repair at all. Followed your advice and bam, perfectly functioning television. Can't thank you enough. The pictures and website were particularly useful.
                                        I have fixed my first tv and am on cloud 9.
