Dell inspiron 3521 la-9104p dead
    Model-Dell Inspiron 3521
    M/B-La-9104p rev 1.0(A00)
    Problem-Dead
    The ene kbc was shorted, so i replaced it with a new one and programmed it as well with Rt809F. unit still has no 3.3v
    I have tried the following:
    01. Replaced another new kbc and programmed-still same
    02. Replaced Pu200 with TPS 51125-still same
    03.Replaced Pu100(ISL88731)-still same.
    04. There is no short on 3v and 5v coils(PL200 & PL201)
    05.Tried flashing both Eprom's-still same.
    I have noticed one thing which has left me puzzled--If i connect pin16 of Kbd Connector(which is connected to pin 42 of KBC) to Ground-all voltaged appears on the board-3.3v at battery terminals and power switch. Mb wont turn on simply coz connecting pin 42 of kbc to Gnd means KBC is in programming mode.
    So whats wrong???
    Please advise friends as i have run out of ideas.
    Re: Dell inspiron 3521 la-9104p dead
    No ideas?? or i'm not clear in my explanation of case?
      Its so difficult to find out .............laptop repair is tough work, sometimes its bother me
        https://www.youtube.com/watch?v=rifMj6ne920
        Check this video you might find it useful and get some more clues...
          This is schematic and bios
          have you a short on 3.3v <-- EC ?
          ____________________
          MOD EDIT: Bios moved to bios requests sub forum
            I remember a similar issue on a thinkpad solved with a pch reflow but in this case you should , In this case you should try to separate 3.3V 5V block from its loads
              Check at PL600 & PL601 for short circuit. And also PU600.
                Originally posted by jasko_jacker View Post
                This is schematic and bios dump,
                No short on 3.3v ec
                  Both the coils are not shorted to Gnd. Checked with a working board. Pu600 is fine
                    i had the same issue on a motherboard. but i don't remember which resistor is damaged. so check resistors around pu200.
                      check RE4 and RE1
                        thanks
                          dears i have a problem dell 15-3521la-9104p)
                          it showing the massage battery not identifed system unable to charge
                          i change battery ,charger
                          chargig ic
                          3,5 ic
                          all starting /charging mosfets
                          near charging ic components
                          pch bios 32/io,bios16 bios programmed
                          io chip kb012qf changed and programmed
                          but no chance please help me friends
                            Can u run the laptop only on charged battery?? Check for shorted caps on battery output lines. What about PS_ID??
                              thanks
                                chargig ic
                                3,5 ic
                                This sort of "hit and trial" approach makes things worse and sometimes render the mb unrepairable. Identify the fault first, understand the circuit or seek help in the forum instead of killing mb's.
                                  thanks
                                    Thank you
                                      Thank you
                                        Thanks a lot guys.
