Major firmware bug found in Hewett Packard Enterprise SSDs!
    Over at bleepingcomputer .com, IIRC, I saw a report of a major Hewett Packard Enterprise (HPE) whoops! It's a major firmware bug that causes their SSDs to become bricked at 32,768 hours!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    16 GB AData XPG Spectrix D41
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    Re: Major firmware bug found in Hewett Packard Enterprise SSDs!
    I guess they better install the HPD8 firmware patch
      maybe they shouldnt be using 15bits to count the hours - fuckers.
      i bet all they do is add the 16th bit so it bricks in 65,536 hours!
      as long as the warranty is over they wont give a fuck - post-fiorina.........
        Those that do not learn from past mistakes, are bound to repeat them?
        https://www.techspot.com/news/82942-...s-patched.html
        https://www.anandtech.com/show/5424/...the-bsod-issue
        https://www.engadget.com/2015/05/01/...-software-bug/
        http://sunnyday.mit.edu/accidents/Ar...entreport.html
        https://en.wikipedia.org/wiki/Deep_I...end_of_mission
          The key word here is "enterprise". I.e., likely the folks running them have support contracts (and/or local staff) to catch these things.
          Also, they are likely to be servers -- in which case, even 24/7/365 operation puts the problem at the 4 year point -- beyond the normal upgrade cycle (so, the guys who inherit the "used" equipment will take the hit!)
          Anything that sees 8 hour/day usage will push that point out beyond a decade.
          [Do you think we worried about Y2k in the 70's when we designed software/systems? Do you think folks are actively worrying about Y2038 *now*?? How many of those firms will still be in business, then?]
            The failure rate is at an absurdly low rate, even for consumers!
