Panasonic touchbook cf-53 mk2/mk4
    Re: Panasonic touchbook cf-53 mk2/mk4
    i tried other MK2 to unlock, changed many things in the file but still asking directly for password, what did i wrong?
    Thank you
      Thank you
      try
        Originally posted by Maxpower3 View Post
        try
        working good
        what did you change in my file please?
          search end of key with uefi tools or compare my file with your . come back if you don't find it
            need more help or pictures please, i do not understand to much
              look in thread
              many occurrence of the end of the old encryption key.
              search and extract with UEFI TOOLS
              write 2 times again
              Search volume contains end of key "D8606B"
                look in thread
                i found 2 times
                is this correct now?
                  i was able to unlock another MK2.... thank you very much for all your help
                  this time on boot is other LOGO not Panasonic Logo and one error see Picture
                  any idea how to change the Logo?
                  Thank you very much
                    at the end of the string there is 01. Do not change it to 00. Otherwise Panasonic logo at boot will go away.
                    you haven't read all thread
                      no no i did not delete 01, original was with Telekom Logo on boot.
                      Logo is there but Telekom not Panasonic
                        ok not understand ,look maybe utility panasonic
                          ok
                            @Maxpower
                            can you please check this file. unlock ok but password return
                            delete all but not working
                            thank you
                              Thank you very much
                              here . EDIT: bios removed.
                                Originally posted by SMDFlea View Post
                                here .
                                with this file no display
                                  You sure its another MK2 ,post the full model number .
                                    cf-53JWX1CFG
                                      @Maxpower
                                      thank you
                                      can not find any more end of key D8606B but still password returns
                                        not find ,look with SMDFlea to clean
                                          cf-53JWX1CFG
                                          Try again .
