Aspire ES1-132, DA0ZHPMB8F0 / F - Bios Needed
    Re: Aspire ES1-132, DA0ZHPMB8F0 / F - Bios Needed
    Originally posted by SMDFlea View Post
    Your serial number should be on a sticker, or you can post your original bios backup, it might have your serial in it.
    https://uk.answers.acer.com/app/answ...-serial-number
    SNID : 64511876776
    https://www.badcaps.net/forum/attach...1&d=1553976440
      Latest bios version 1.26 + EC
        i will try
        thank's
          now is oke, but keybord not work
          i am cek from pin soket keybord and it8987e, something voltage mX0=0,034v is drop and mY16,mY17 =1,2volt
          is problems on the it8987 or from others ????
            I don`t have the es1-132 schematic.On the es1-131 schematic MX0,1,2,3 are pulled low # through a 10K resistor. I think your keyboard needs replacing.
              ok , i try replace keyboard again,...
                after i change it8987e,is keyboard working
                thank's all
                  Here you go.This EC is version 1.15 ,it matches with the bios at post #9. Backup your EC first, it may have your DMI info.
                  Sir,what does this EC bios do besides the main bios?
                    Just wanna ask how to reprogram EC bios.. of this ES1-132, I have programmed the main bios but still nothing.. still with power no display..I only have Rt809f programmer with me.. thanks
                      is this ec bios ic???
                          Try this bios .
                          Thanks to this sir , tested !
                          Happen to solve bios password problem..
                            EC ic can be seen under wifi module
                            regards,
                              many thanks for sharing...
                                I need BIOS for ZHP ( 1MB ) 25q80BWSIG
                                IC U28 - bottom of WiFi card.
                                Please
                                Thank You
                                  DA0ZHPMB8F0 rev f latest bios
                                  Hi hope someone can clean the bioswith latest update
                                  It has no display
                                  DA0ZHPMB8F0 rev f
                                  laptop model :
                                  ES1-132-C5YH SNID: 83013091276
                                  MFG DATE: 2018/07/30
                                    Re: DA0ZHPMB8F0 rev f latest bios
                                    It has no display
                                    DA0ZHPMB8F0 rev f
                                    laptop model :
                                    bios extracted from the Acer site update
                                    KEYWIN 385000-38503F
                                      Try this bios .
                                      thanks, this bios is very good for me
                                        Try this bios .
                                        thanks
                                          Please
                                          Thank You
                                          I need this too. Anybody?
