X200MA Bios dump needed
    Re: Acer X200MA & Acer X200CA shut off after 10 minutes
    Originally posted by aris_prast1 View Post
    IM sorry. Not Acer. Asus...
    you properly check maybe in this laptop your CPU over hitting otherwise CPU not over hitting so check your graphic chip hitting normally in this laptop power off time graphic chip problem
      Re: Bios dump needed
      For asus try this one
        thank u for all
          1st x200ma bios not working
          2nd x200ma bios works! FOR ME
          Thanx for you all!
            Re: Asus X200MA please help me.
            Originally posted by fddizon View Post
            try this bro... working bin
            let me try
              working tested ok
                Originally posted by naseee View Post
                working tested ok
                thanks...
                  Originally posted by Francisco.s View Post
                  Try this dump. (it is from a working laptop)
                  Hello everyone
                  Device: Laptop
                  Brand: Asus
                  Model: X200ma
                  Board no.: X200ma REV. 2.0
                  Request: working Bios bin
                  Issue- laptop comes up and goes off, all power rail present
                  Please I search first, and saw similar dump but different REV, mine is REV 2.0 but I saw REV 2.1 CAN I reprogram with a dump of different Board REV?
                    Originally posted by Epilsantoh View Post
                    Hello everyone
                    Device: Laptop
                    Brand: Asus
                    Model: X200ma
                    post the backup of the original bios
                      Re: X200MA Bios dump needed
                      tHANKS YOU GUYS
                        Does anyone have x200ma rev 2.0 bios?, im got blank screen and 3 led on (charging, power and wifi), battery didnt detected when charger removed (battery still 87%)
                        And im got noise sound around pjp8102 but voltage show 5v (not 5.12v) and pjp3001 (not nonnect) show 3.3v and 0.5v (each separated jumper)
                          post the original bios..
                            Here, it rev 2.0 board, and most bios i see is rev 2.1, sometimes power button only 0.37v
                              try post #26..
                                try post #26..
                                Still not work, 3 led are on and stuck at there (power, charging and wifi led on)
                                  Write your device serial number.
                                  all donations are welcome,
                                    Why?
                                      Why?
                                      To know the right model number and get the right file from Asus website.
                                        Here
                                          That is not the unit sn.
                                          look at a stiker on the bottom plastic
