peavey xr1212
    peavey xr1212
    hi guy's im looking for a service manual for this peavey xr1212 mixer....
    i have 2 parts that are burn and would like to replace them but cannot see info on them.....location is q3 and q4
    so basicly,when client brought me this mixer,he have already took out these 2 parts....and what he told me is that the mixer have power but no light or disply,ect...but that the powerboard come very hot and start smelling like burning.....
    so i kind of need these parts to make further test.any help would be very nice.thank you
    Re: peavey xr1212
    have you got the schematic ? if not email peavey for it
      Re: peavey xr1212
      i tryed,but never got a reply.....will try again
        Re: peavey xr1212
        Well from picture 9 -gb19nc60kd
          Re: peavey xr1212
          If these two fets are blown, I suspect the driver ic is also blown, check the resistors connected to the gate and follow them back to the drive circuit. I suspect there are more issues, hopefully Peavey will provide the schematics
            Re: peavey xr1212
            thanks for the info,i will do as you told me to check.and yes peavey send me all schematics for this units,i let you know my progress.
              Re: peavey xr1212
              Can you upload the schematics?
                Re: peavey xr1212
                Originally posted by r_j View Post
                can you upload the schematics?
                +1
                  Re: peavey xr1212
                  +2
                    Re: peavey xr1212
                    hi guy's sorry for late info but like you asked here are the peavey shematic that peavey send me.
                      Re: peavey xr1212
                      https://www.mouser.co.uk/ProductDeta...AzAAUcdTHQmQ==
                        Re: peavey xr1212
                        Thanks for posting these schematics!
                        Hoping to repair the speaker outs on my xr 1220.
                          Re: peavey xr1212
                          Hi, hope the pic will be useful for you, I had same problem blown mosfet, the part number is 26NM60N. the SMD diod marking is 14G.
                            Re: peavey xr1212
                            attached pictures
                              Re: peavey xr1212
                              Interesting ... that mixer uses the same amplifier board as the Peavey IPR1600 power amp ...
                              The original 2x components were IGBT's but several other fets can be used to replace.
                              Be a good idea to remove the amplifier side power fets and check them or you may blow the new PSU fets again on 1st power up.
                                Re: peavey xr1212
                                Peavey is a great company when it comes to providing schematics, etc. They will also sell parts if they have them, and they have had some parts to some very old amps I have repaired.
                                  Re: peavey xr1212
                                  Hi Guys,
                                  Apologies for picking up on this fairly old thread.
                                  I have several Peavey XR1212's in my possession, and have built up a reasonable degree of expertise in diagnosing, localising and repairing the main power boards.
                                  Being SMD they are not easy to work on, and require a fair bit of dexterity with a soldering iron/heat gun! Not sure whaat solder was originall used, but it has a VERY high melting point!
                                  Interestingly, I have had issues identical to those described here, with regard to Q3 and Q4 giving up in spectacular fashion. They do appear to be a point of weakness on this board.
                                  I am about to replace these, so will post back in due course.
                                  If anyone has any additional detail, please post it.
                                    Re: peavey xr1212
                                    The same main board is used in the XR8600D (not XR8600) as far as I can tell.
