OK i received this TV and it only has sound. you can hear the system play anything as such i plugged in a Xbox to the hdmi and it was playing the game but it didn't have any back light. i checked the voltage to the man board from the all in 1 power supply inverter but im not sure where i should check for the backlight side. ive got the board out and everything looks good at least no burnt traces or anything. both fuses are fine it just seems like the high voltage side is not working? any suggestions?
samsung ln40b530p7fxza light up problem
Re: samsung ln40b530p7fxza light up problem
Originally posted by gmzombie View PostOK i received this TV and it only has sound. you can hear the system play anything as such i plugged in a Xbox to the hdmi and it was playing the game but it didn't have any back light. i checked the voltage to the man board from the all in 1 power supply inverter but im not sure where i should check for the backlight side. ive got the board out and everything looks good at least no burnt traces or anything. both fuses are fine it just seems like the high voltage side is not working? any suggestions?
1. Review your composition classes. Proper capitalization and spelling structure assist in comprehension by the reader. Breaking it into short paragraphs also help.
2. Pictures are a great help. I suggest starting with a single over-all picture of the back side of the TV (with back removed, of course). This allows identification of interconnections between various boards.
3. When listing a model number, do so exactly as printed on the label. The base model number in this case is LN40B530. The service manual is here. Unfortunately, most service manuals do not include the inverter.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
https://www.badcaps.net/forum/showthread.php?t=14644
Check here, should be the same power and inverter circuit.
OK to update here are some pics of the whole backside of the TV. Then i took 3 pics of the power supply board, A whole pic, a left half, and a right half. There is also a pic of the main board, and the tcon board.
I have verified that if you put a flashlight behind the LCD it does in fact show a picture. I have checked all the diodes in the board and they all show a rating on one side and infinite on the other just as they should.
I thought i had the right model code but it seems to be this Samsung ln40b530p7f. Hopefully this helps out so i can get this diagnosed and repaired.
Also i tried to download the service manual but it wouldn't let me. it said 2 downloads per guest per day. I'm using Firefox so that isn't the issue.Last edited by gmzombie; 07-09-2011, 08:15 AM.
Originally posted by gmzombie View PostOK to update here are some pics of the whole backside of the TV. Then i took 3 pics of the power supply board, A whole pic, a left half, and a right half. There is also a pic of the main board, and the tcon board.
Points to check:
1. It may be necessary to register on Elektrotanya. It's a free registration and I haven't been spammed as a result, so it should be safe.
2. Refer to the last picture. Above and to the left of the bar code label is the pinout of the output connector. Check the voltages.
3. Note the transformer bottom center of the same picture. Is that scorched or is that dust? If it's scorched, QGAH02095 is available on eBay.
4. Pictures of the bottom of the inverter will help troubleshooting if the brown spot is dust.
1. i tried this and it said it was for invite only.
2. i checked the pinout output voltages and they all seem to be in spec. 13v was at 13 5.3v was like 5.32v and whatnot.
3. it is not dust that is for sure. so im assuming that it is scorched but is there a better way to tell.
4. I will have to get you a picture of the back side of the power supply board tomorrow. its late now.
Originally posted by gmzombie View Post1. i tried this and it said it was for invite only.
2. Good
3. Compare the resistances of the secondaries
4. Whatever.
ok i hope i did this correctly
i took measurements on both sides of those qgah02095 and on all 4 of them
first one closest to power plug
side of light plugs 3 is the scorched one
(1.)1.19k /1.18k (2.)1.19k/1.18k(3.) .955k /8.3mega (4.)o/l / 1.2k ohm
other side of qga's
(1.) .1/.1 (2.)1.8/1.9 (3.).1/1.9 (4.).1/1.9
Also did you figure out the register for that site?
other side of qga's
No, I haven't. I've been goofing off.
PlainBillLast edited by PlainBill; 07-14-2011, 09:50 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Originally posted by Village Electronics View PostDon't sass the customers Bill or you're going to get a cut in pay.
Here's what you or anyone else must do.
1. Go to Elektrotanya.
2. In the left hand Navigation menu click on About Site
3. Click on fill up an electricity test.
4. On the next page enter your email address
5. Then answer 5 simple electronics questions.
Originally posted by PlainBill View PostWell, sort of. I haven't figured out how to issue an invitation, but an invitation isn't necessary.
PlainBillThe strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Originally posted by gmzombie View Postjust to update replacing both inverter transformers fixed the tv. it now turns on and i can see it again.. thanks for your help.
Thanks for sharing and your help.
I had the same problem on the same tv. Screen turns off and on. No problem with the sound.
So I saw this forum and dissassemble my tv and have seen the damaged transformer.
First I bring the board only to a "tv repair". They wanted to have the all tv and replaced the entire board for 250$ and keep the old one. They cannot put a new transformer.
I said no and order a new part on ebay (+ a soldering iron in my city) and put the new transformer.
The tv works now pretty well like before. Good for watching "rugby world cup"
sorry for my english and thanks again!
