Help with capacitor for Asus Radeon 6870
  • wordsworth
    • Sep 2021
    • 5
    Hello, second post here and as many do I'm seeking help in reading markings on a capacitor to replace it on a graphics card, an Asus Radeon 6870. I'll just say I had an accident and knocked off a capacitor between the card's rear bracket and the heatsink; the location is marked PCE104.
    Anyway, on the capacitor which you can see others in the image it says 5KR43, 270, 16V. I understand the 270 to be the capacitance and the 16V obviously the voltage; but I don't know if the 5KR43 numbers and letters each have meaning or is simply the number of the manufacturer's series.
    I have spent some time at digikey.com but don't really yet know exactly what I'm looking for without at least knowing what the 5KR43 number/letters mean. Can anyone help read this and/or point me to a capacitor that may work.
    Thanks for any help.
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    Re: Help with capacitor for graphics card
    That circular thingy next to the "2" of "270" is the manufacturer's logo, which I don't recognize. The "5KR43" is probably the manufacturers date and/or factory code (probably both).
    The part is probably a polymer capacitor, so a good manufacturer's 270uF, 16V polymer capacitor of the same diameter and height should work OK.
    PeteS in CA
    • wordsworth
      • Sep 2021
      • 5
      PeteS in CA, thanks for the quick reply. I thought the circular thing a brand logo as well. I'm going to do more looking and take some measurements then post back here on what I find. Thanks for the help.
      • wordsworth
        • Sep 2021
        • 5
        Re: Help with capacitor for Asus Radeon 6870
        Going by that discussed above I'm looking at getting this
        https://www.digikey.com/en/products/...MDO1TD/5180964
        Any thoughts?
          master hoarder
          • May 2008
          • 12168
          • Bulgaria
          That little logo denotes the capacitor is made by Apaq... which is pretty much what ASUS uses all the time.
          "5KR43" string indicates the series and date code, with "5K" meaning these are the AP-CON AR5K Series. R43 is the date code... but we aren't really interested in that.
          Going by the above datasheet, ESR is listed as 10 mOhms, and RC (ripple current) as 5000 or 5230 mA, depending if the height is 8 mm or 11.5 mm.
          The Nichicon PLS cap you have picked on digikey is pretty close and should work fine - just make sure its height is appropriate (12 mm) and will fit as a replacement.
          Otherwise, a slightly cheaper (40 cents, lol!) alternative is this Sanyo SEPC, which has the same ESR and RC ratings as the Apaq 5K that was originally on the card.
          Another option is Nichicon PLF series.
          • wordsworth
            • Sep 2021
            • 5
            Thank you momaka for the information. I had looked at images of many Asus graphics cards on the web and saw that logo often so am not surprised that you say Asus uses them a lot.
            I have gone ahead and ordered the capacitor I linked to above as it is the closest I can find taking all the specs into consideration. Thanks again for the info.
              AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
              The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
              10-01-2024, 12:46 PM
              AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
              The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
              10-01-2024, 01:07 PM
              AMD Radeon RX 470 / RX 580 Schematic & Board View
              The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
              10-01-2024, 12:52 PM
            • MeetingIncapable
              Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
              by MeetingIncapable
              I am new to repairing computer electronics, so excuse any mistakes I make.
              A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
              I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
              I wanted to replace the capacitor, but I have two questions:
              • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
              • How do I determine the rating/value of this capacitor? or something
              05-04-2024, 09:56 AM
              Thermal pad thickness for various laptop GPU / Graphics Cards
              ASUS Dual RTX 2070 OC 8GB
              ASUS ROG STRIX RTX 3080 OC
              ASUS ROG STRIX RTX 3090
              ASUS TUF Gaming RTX 3080 OC Edition
              ASUS TUF GTX 1660 S-O6G GAMING
              EVGA RTX 3060 Ti XC GAMING 8GB
              EVGA RTX 3060 XC GAMING 12GB GDDR6
              EVGA RTX 3080 FTW3 ULTRA GAMING
              EVGA RTX 3080 TI FTW3 ULTRA GAMING
              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
              Gainward RTX 2080 Phoenix GS Specs
              Gainward RTX 3070 Phoenix 8GB
              Gainward RTX 3080 Ti Phoenix
              GIGABYTE AORUS RTX 3080 MASTER 10G
              02-09-2024, 08:08 AM
