Unconfigured Static HTML Module
Static HTML Module Content
Let's talk about SCADA
    Good day folks. As some of you may know from some of my stories here, my boss always likes to take on new and interesting projects he comes across, especially if there's a lot of money involved, so he ropes in average Joes like yours truly for the job, even though they've never done said thing before, so you only have like 1 week to learn it
    This year's trend and topic seems to be all about IoT and SCADA systems....big topic, so I really don't know where to start with this. I know what it is and I understand the concept, so I guess the best place to start is the beginning: what we want to achieve.....we're not entirely sure yet, so this is mostly going to be a speculative discussion, discussing the good, the bad, the ugly, the dos and don't, ins and outs of SCADA.
    From what I understand, the end goal of all this hype is going to be for us to be able to take over the maintenance and operation of some floodgates....yes, that's right ! Not some small insignificant prototype device on a workbench, but actual goddamn floodgates, complete with ships passing through and everything ! We're not going to go into management stuff here because I don't (want to) know that part myself, but from what I gather, the contract between this compound and the company currently in charge of support is about to expire and of course our boss wants to take over at that point....cool
    It's very early to know anything about the systems or particular equipment they're using, though I HAVE been in the control room once and saw the monitors showing the schematic representation of the compound and the different parameters and stats of the valves, sensors, pumps, servos, along with the main gates themselves. Aside from the sheer scale of the thing we're talking about here, it's not really that spectacular in the grand scheme of things: a PC interfaces with some widgets via (what seems to be called) a "HMI" and back....that's SCADA.
    Now to make our own I found a variety of resources online, ranging from small DIY stuff based on Arduino, to proper industrial-grade devices, which is what these guys actually use. The software used also seems to be diverse, again, ranging from stuff some chap wrote himself in Visual Studio, to industry-standard programs that comes with the hardware used there. I'm not a software buff as you may know, so this is where I'd like some help first.....suggestions ? What should we use ? Simple-Scada looks like a nice pre-made piece of software I found, though it seems to be in Russian, and of course we can go full-DIY by using Visual Studio itself to at least play with some pre-made programs, since I'm not sure I'd be able to learn C# like that
    If I understand correctly, it works like this: the PC program with its visual interface the user clicks on spits out some commands over a COMx port via a MODBUS (?) protocol. The Arduino set to the matching COM port and baud rate like any serial device, with a MODBUS library loaded onto it, responds accordingly to either read something, or issue a command to an output...plenty of stuff to talk about here...
    Wattevah...
    Re: Let's talk about SCADA
    THIS is a good example that comes fairly close.
    I'm already thinking of implementing something like this to monitor those sewage treatment stations I talked about in my PLC discussion so we wouldn't have to go in the field to do it. Connectivity will be an issue, so I also have to come up with some sort of GSM/Cellular connection for them to report back to the main office or monitoring station...
    Wattevah...
      We have a machine where I work that uses this system
      https://infosys.beckhoff.com/index_en.htm
      9 PC LCD Monitor
      6 LCD Flat Screen TV
      1 Dell Mother Board
      15 Computer Power Supply
      All of these had CAPs POOF
        Beckhoff...interesting. There, see ? Plenty of different solutions out there. They're probably proprietary too, so it involves knowing exactly which one to pick up and learn....the more, the better of course.
        Wattevah...
          Yes and from the little bit that I have read on this system it is quite involved when I have problems with this machine I have to call tech support for them to help me with it
          One note
          This machine is back in the 2000s I think
          9 PC LCD Monitor
          1 Dell Mother Board
            Everything DIY seems to revolve most around Visual Studio, so it looks like the perfect opportunity for me to learn something new
            Wattevah...
              dont get involved.
              one word: LIABILITY.
              soon as this fucks up and floods someone or damages something your boss will be on his way to tel-aviv or the nearest border leaving you and your workmates in the shit.
              i'd be curious how the hell he got the contract with no prior work to show!!
                incidentally, critical monitoring such as water or gas distribution does not use public networks - they use a private radio frequency and commercial transceiver modules - i'm sure you can work out why.
                  Ok, no, don't worry, it's not AS crazy as it sounds: we won't dive head-first into this on our own, with nobody there but us newbies - there's plenty of staff there who already handles all the critical work, plus I won't actually DO anything, other than maybe inspect and report defects to the higher-ups.
                  This perfectly reminds me of the Chernobyl series on HBO, where untrained staff were forced into doing stuff they were aware was dangerous and would lead to failure, but they HAD to comply.....
                  Also one word: CONNECTIONS
                  Wattevah...
                    You start with the I/O (point) count - how many digital in's/out's, analog in's/out's. This tells you how big the control system need to be. If the site wiring diagrams and floor plan are up-to-date, that helps too.
                    Usually a PLC is used for local control (i.e. stopping motors due to limit switches) etc. so the system can work safely even if comms is down. Yes an Arduino and custom I/O board can be made and work... but you are the only person who knows how it works and if you get hit by a bus - then nobody can make a program or hardware change easily.
                    Coding it (controls) on a PC is silly because they aren't reliable enough for anything past the HMI/logger. Windows update? Anti-virus update? Your program gets overruled and big drama results.
                    A big decision is if you are doing controls (outputs) over the Internet. Easy SCADA is "eyes only" where you just watch inputs and never start/stop a pump or something. But if you are remotely turning on equipment, there is always a safety hazard somebody gets squished or hackers get in and cause trouble. You need AUTO/MAN/OFF and LOCAL/REMOTE switches as a minimum on both the HMI and at the PLC.
                    As far as the HMI, it's always basic MODBUS comms to the PC and HMI software running on that. Take a look at DaqFactory it's low cost.
                      indeed, i wouldnt trust an o.s. if i could avoid it - just have the code running stand-alone on the hardware.
                      and write in in c or assembly - not some convoluted bullshit that when compiled has no resemblance to what you wrote.
                      because you will never find a compiler bug!
                        To me any system that is critical systems should not any access to the outside world you are just asking for trouble that just my thought about this subject
                        What gets me with this country is that are electrical grid and water supply system and the like are all accessible from the internet really ( you can automation with out being on the internet to be done remotely really get off your ass go to the site and fix the problem)
                        All you need is a good hacker to cause you nothing but grief
                        What has surprised me that we have not had major issues with this kind-a thing yet
                        The views that are in this post are my own and do not get me wrong I not saying that it should not be access by tech support when you the owner or operator turn this feature on so things can fixed once things are taken care of turn this feature off when not in use and not need
                        Do not make things easy for good hackers
                        9 PC LCD Monitor
                        1 Dell Mother Board
                          I think punctuation got lost somewhere along the way
                          There's actually 2 of these compounds and a head office all connected via fiber and a backup radio. The fiber's been down for a solid year now, since it's been ripped and torn to pieces in various places along the canal, so in reality communications is only by radio ATM, since it's us, our company, who is in charge of it, apparently. Some of the boys just recently froze their asses off to install some masts and antennae in the middle of nowhere for this purpose. Of course, I don't actually KNOW what info the compounds exchange about one another, or IF they do at all, or if one can be remotely controlled by the other or from the head office, but I imagine they at least report their status back and forth - makes sense.
                          Off the shelf equipment is most likely what these guys use - there are some racks with some pretty serious looking equipment in that control room there and the control PCs boot Linux to run that control interface ! Pretty intimidating stuff...I can't imagine what it'd be like if something went wrong there ! :|
                          Wattevah...
                            I reckon those Xinje PLCs I messed around with in the past when I was told to rethink those water treatment stations some of you may remember are also capable of being part of a SCADA system. According to page 163 of their manual, they use MODBUS as well, so the C# software everybody seems to recommend can interact with these instead of the Arduino...it's a good starting point because I already have a couple of these PLCs still doing nothing, so it would be a hands-on experience. The interface would still be serial RS232 from the back of the PC on my desk, so I'd need to figure out a way to make this remote when it's time to deploy these in the middle of nowhere....
                            Wattevah...
                              The hard part is understanding the old control logic and wiring.
                              Is this a split bridge? There's extra code to deal with one end malfunctioning (thanks for wrecking my yacht) and collisions, power failures etc.
                              If you need to go low-tech on the communication link, modbus over TCP/IP or even RS-232 over TCP/IP. I don't how the bridge could have ethernet?
                              Some sites I use private 900MHz radio (serial) links for two PLC's to talk to each other over a short hop.
                                No, it's not quite a split bridge like the one pictured, though one of the compounds DOES have a single-leaf (?) drawbridge as part of its system. This is actually a water-lock: it lowers or raises the water level depending on where the ships come from - either upstream or downstream. The waterway is split into two right down the middle, so there's one water lock on either side, that means 4 individual gates, plus other devices to regulate pressure and water level and stuff. The control tower sits on an island in the very middle of this whole setup, between the 2 locks. The bridge I mentioned is used to allow vehicles to get to the middle part if need be. Having visited this place many many times so far for other duties, I noticed this bridge is kept raised almost all the time because vehicles need to cross over only on very rare occasions, so it makes most sense to just keep it out of the way all the time, to decrease the waiting time for the ships. Personnel, on the other hand, crosses from the control tower in the middle to the banks and back by walking across the top part of the gates themselves, where a pedestrian bridge forms once they close. That's just backstory to better explain this whole compound. It's all academical really, because there's no way you can be expected (make that "ALLOWED" ! !) to run all this willy nilly like that or even get close to the heavy duty machinery that runs it all. It WILL happen though, slowly but surely
                                Wattevah...
                                  It sounds like a good project, it could be fun. Although water sensors are not very reliable. Some SCADA projects work terrible only because the sensors are terrible. I usually upgrade any sensor they have had ongoing problems with. Like a level sensor.
                                  I would start with tons of photos of the site, and get the I/O point list, or "taglist" as it's called in SCADA. If you know how much I/O plus spares for future additions, then you can size the PLC and HMI. If you choose too small a PLC it's a disaster.
                                    Well the compound is currently fully operational and will most definitely remain so in the future as well, so we don't actually need to reinvent the wheel here and deploy any complex equipment of our own or implement anything from scratch. We DO need to get a good understanding of the existing setup - good or bad - and, at the very most, suggest improvements where needed/possible.
                                    That doesn't mean I can't do small-scale prototyping on the bench to familiarize myself with all these concepts, like MODBUS, hence why I wanted to build a bench-sized SCADA of my own. Once that's done, it would be MUCH easier to move on to the real deal and it would look more professional if we know what we are doing instead of just stumbling around wondering what's what. Sure, the floodgates probably don't run off an Arduino, but the concept's the same in the long run. I think it may actually be MORE challenging to design your own HMI than using a pre-made one !
                                    Wattevah...
                                      I used GE Cimplicity HMI, I think $5,000 for a dongle. The GE ecosystem is crazy expensive, especially for the nuclear power/coal plant DCS. Very hard to program too, it's all quirky, nothing is straightforward.
                                      In MODBUS, there is a Force Multiple Coils (Function Code 15) command which activates multiple outputs all at once. I'm not sure what it's good for. You always use Function code 05 to turn on a single output.
                                      Guess what, the crappy GE Cimplicity program defaults to send FC 15!
                                      So a coworker programmed up the HMI and later a tech went to turn on one output... It shut off power to the entire town, every breaker switched off at once. What a fiasco.
                                      Point is, MODBUS is simple and easy to use but because the standard is poorly defined, companies do their own thing with it and that can be hard to troubleshoot.
                                      We always set up testbenches in the office, with an entire RTU/PLC and HMI to do programming and test. It's too costly and dangerous to debug on site.
                                        Good to know. These guys may very well be willing to invest an insane amount of cash in this project like that in the long run, hence why it'd be ideal to keep costs to a minimum so the bulk of cash goes to us as profit...if that makes any sense.
                                        I've been learning about MODBUS lately and trying to figure out how to implement it on those Xinje PLCs outside its own little piece of software. The manual has quite terrible English translations, no doubt from Chinese, so I could not figure out how all the bits and bites work to do what. All the video tutorials I've watched so far make it quite clear that in order to tell a PLC to do something, you have to use proprietary commands, since they differ between brands, so they all direct you to the product's manual or datasheet. If this were Siemens or other proper brand, I'd no doubt find this info somewhere, but I'm a bit stuck ATM. Sure, I can control the PLC with its own software, but what if I want to send it commands through a third party piece of software which has a graphical interface and all that ? THAT'S what I'm struggling with ATM.
                                        Wattevah...
