View Single Post
Old 10-11-2021, 03:06 PM   #2
AleXis6
City & State: Minsk
My Country: Belarus
Line Voltage: 230VAC 50Hz
I'm a: Knowledge Seeker
Default Re: Old electrolytic capacitors
1. As a read producers adviced to keep capacitors in ziplock packs to prevent shortage of their life
2. I bought LCR meter and evaluate the capacity, ESR, Z, D and other parameters and compare measured numbers to datasheet.
DC leakage is easy to measure just with a millivoltmeter.
Capacitors with high ESR will not necessarily fail immediately, but the operation of the equipment may be unstable, the symptoms will increase over time and under heavy load. If you replace a bad capacitor in time, you do not need to change the other components.
AleXis6 is offline   Reply With Quote
