Sharp LC-70C8570U
    Sharp LC-70C8570U
    I have a sharp tv with a blink code of 2 blinks and 5 flashes. I have no back lights when it is powered on.
    I removed the back and tested all back light. They all work.
    I took reading and it seem everything points to the main board. Any help... im also thinking i will need schematics for this tv and a reset to get rid of fault code.
    The tcon board looks like it had some thermal issues from pictures
    Re: Sharp LC-70C8570U
    1st of all how did you test the backlights did you remove the LCD panel in physically power the backlights with a dmm?
    If you look on this forum you will see many postings about faults with sharp LCD TV's especially the 70 Inch panel. When you 1st power the TV do you get a solid light light before the 2 - 5 Flash? Do you see any indication of the back lights coming on even briefly before shutdown? Also we would watch your monitor voltage to the tcon. you should be getting 12 v to the connector
      pin 15 stby voltage is present, but pin 14 ps/on command is missing.
      so right now you are not getting your on command from the main board to turn on the ps.
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        Hold down ch+ vol- power while plugging it in. Or try ch- vol+ power.
          if your attempted "power checking" was done with the tcon disconnected as shown in your pictures, then it is unlikely that you will get "ps-on"... you need to have at least one "side" of the tcon connected to something (ie. two cables).
            I believe sharp tcon will function without the panel connected is long as a tcon is connected
              I have a led backup light tester for leds.
              I removed led and tested then individually.
              When i power on tv, i got nothing from panel no lights.
              I tried the fault re set combo but may be im doin it wrong.
                Also plugged tcon board back in...
                Measure 0v tcon connection on main board also
                  Sorry.. i miss spoke..
                  No 0v on tcon board should be 12v
                    I am suspecting main board....
                    Any schematics or where i might find...
                    This board is expensive and hard to find...
                    Dkeymf953fm01... or would fm06 or other versions work
                      Ok retested and used the right fault reset
                      Vol down and input..
                      Had 12v on tcon board....
                        Green led light is flashing on main board...
                        I am goin to retest power supply point..
                        Still same fault code 2/5 no leds light up and they were tested good
                          Ok results from power supply reading.
                          Also reading from Led connector 83 volts.
                          This is with power ON condition
                            Ok new reading from bridge rectifier and regulators on the board... i think i am getting close
                              Okay all this is going on with the panel connected to the T con or not?
                                Yes all connections are made on tv
                                  Yes t con board is connected
                                    Ok try the same procedure with all 4 ribbons disconnected from tcon to panel. That you will still have the tcon connected to mainboard Then try just the left two thenr the right two
                                      Ok i will
                                        Right ribbon cable disconnected /left connected to t-con board.
                                        -no fault code flashes
                                        -no picture or backlights
                                        Left ribbon cable disconnected / right connected to tcon board
                                        - 2/5 flash fault code
                                        - no picture or backlights
