LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by daniel0314 View Post
    i have same problem
    any solution?
    ...it is not same problem i mean...because L13 have core 10gen+ and this is not unlockable with this solution.
    You must start again. Flash original image and power on and go into locked bios. Then power off, then autopatch bios image (check for errors), flash it. Disconnect all batteries (main batt, second batt, bios batt). Press and hold small tamper swich on mobo...it must be pressed during whole process. Connect charger and wait...laptop will make some self reboots and then will maybe stuck on logo...no problem...power off and on and quickly press manytimes f1 for enter bios.
    If it want pw, then fill any pw....and wait, then enter , wait and spacebar 2 times.
    after this power off and flash back your stock backup
      Originally posted by CornholioGSM View Post
      ...you must wait...and maybe make some reboots.
      all batteries disconnected and pressed switch on mobo
      Yes all batteries disconnected and switch pressed / the same nothing only beeping
        Thank you very much sir....
          Please patchi this File for me , as really indeed. my Patch not working just popup the python file and then close in microsecond. Kindly Someone Patch this file for me, T
          Thanks in advance
            Worked perfectly on T560.
            Disabled Supervisor Password and Computrace.
            I used Windows10 with Python 3.8.0 64Bit.
            Thanks!
              Thanks in advance
              read my previous post about python folder
                Thanks in advance
                The Auto-Patcher does not work with a Lenovo T510.
                Only for 4th to 8th Lenovo generation.
                The EEPROM Lenovo T510 is unlocked with the paper clip trick.
                EEPROM U30 short pin 5 + 6
                Google is your friend.
                Try ...
                  Hi everyone
                  How can I remove a Supervisor password on a Lenovo Thinkpad P73 ?
                  Thanks !
                    Try ...
                    ...yes...because this thread is only for newer models from approx 4gen+ intels.
                    Originally posted by fioucs View Post
                    Hi everyone
                    Thanks !
                    ...p73 is 9gen intel ? i mean that this is too much new and unlock is not simple. Your password prompt is white text on black?. if not check this https://www.badcaps.net/forum/showth...&highlight=t14
                      ...put all files from autopatcher folder into root of python folder, then drag and drop origbios.bin to autopatch.cmd
                      Still no luck. Everything in Python310 folder, including the .bin file, but same problem
                        What model is it you`re trying to patch.
                          T440p, dump attached
                            https://www.badcaps.net/forum/showthread.php?t=81573
                            Become a Badcaps supporter
                            Thanks to all supporters.​
                              BTW your dump doesn't look good, so I'll suggest to read your bios chip again, and this time use verification, or you'll have a big problems (at step 8)!
                              Originally posted by Knucklegrumble View Post
                              [ HOW TO USE THE PATCH ]
                              STEP 1: Flash and replace current BIOS with the generated patch file
                              STEP 2: Boot the machine
                              STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                              STEP 4: Enter any character when asked for Supervisor Password
                              STEP 5: Press enter when it shows Hardware ID
                              STEP 6: Press space bar 2x when asked
                              STEP 7: Turn off machine
                              STEP 8: Restore original BIOS
                              STEP 9: Reset BIOS settings to factory default
                                Hello, nobody noticed that this is the wrong BIOS file. (8MB)
                                On a Lenovo T440p there are two BIOS chips one 8MB and one 4MB.
                                Only the 4MB can be patched.
                                The left Chip U49 is the right one.
                                It's a Winbond 25Q32FVSI0 Chip
                                Believe me I've unlocked four Lenovo T440p already.
                                Good luck ...
                                  Originally posted by LatinMcG View Post
                                  Patch for T495 (Amd Ryzen) i posted works with the generator from LBE !!
                                  did you get the key
                                    t490 password removal
                                    hi can someone help remove password on lenovo t490 ?
                                    thanks in advance
                                      can help with this issue, i patch the bios but only beeps and no video
                                      regards.
                                        Good luck ...
                                        Thanks, I will give it a try
                                          Some modern Lenovo devices, in order to work with the patch file, you have to remove the TPM chip or chip in order to work, and then you will install it
