RCUnlocker
    Re: RCUnlocker
    Originally posted by Albo89 View Post
    someone can help me? thank you in advance
    In the rar file you posted there are 4 backup files and they are all different, where do these files come from? Which file is the file from your bios chip?
    Become a Badcaps supporter
    Thanks to all supporters.
      Re: RCUnlocker
      No comment... except many many many thanks! Just read the chip with CH341 live (no need for solder/desolder) with clips, use the unlocked bin to write back and bingo... Job done! Another HP 440 G7 unlocked!
        Re: RCUnlocker
        all files attached, are images of the bios, copied many times, before erasing the chip near the ram slot
          Re: RCUnlocker
          Pleas help me to unlock bios hp probook 1014 G1
            Re: RCUnlocker
            Here
              Re: RCUnlocker
              thank you goods tool
                Re: RCUnlocker
                Hi! What does "live" mean? Need to remove SSD and DRAM? What to disconnect and what to connect: power supply, battery and CMOS battery?
                  Re: RCUnlocker
                  Disconnect : power supply, battery, cmos battery.
                    Re: RCUnlocker
                    hoaca388, thank you. But, in here the developer writes "DO NOT disconnect charger". I want to clarify - how is it right?
                      Re: RCUnlocker
                      Do not connect any power when reading the chip, the power to the chip is now provided by the programmer ( pin 8 is Vcc , pin 4 is Ground)
                        Re: RCUnlocker
                        good den. please delete the bios password. thanks
                          Re: RCUnlocker
                          Here your unlocked file.
                          all donations are welcome,
                            Re: RCUnlocker
                            Originally posted by zelenborg View Post
                            I have tried flashing chip on back side with method from the video i linked 3 posts above. But it is still asking for bios admin password. Also when i turn on the laptop it is showing company logo, not HP, but company that used to own that LAPTOP. might that be the problem why flashing did nothing?
                            Any help is welcome.
                            What is the name of that test clip you use on the picture? Thay can read flat bios chips on hp?
                              Re: RCUnlocker
                              Hi! My HP 8470p has BIOS Password. How can I unlock it?
                                Re: RCUnlocker
                                use RCUnloker (see post #1)..you also need a SPI programmer..you need to read the bios chip, delete the password and rewrite the chip...see more videos on the net..
                                https://www.youtube.com/watch?v=DWWigscuQDY
                                  Re: RCUnlocker
                                  @peste
                                  Thanks for answer!
                                  I know about hardware method, I thought I can use RCUnloker without desoldering BIOS chip. Anyway, ThankYou for answer!
                                    Re: RCUnlocker
                                    @peste
                                    Thanks for answer!
                                    you can not remove the bios chip from the board, but you have to stick wires between the programmer and the chip.. because with the clip from the programmer if you don't have firm contacts you will have errors..
                                      Re: RCUnlocker
                                      Usually the clip is not the issue. For me atleast. I'm using the blue ponoma clip.
                                      WITH MY PROGRAMMER (raspberry pi), I connect power on Elitebooks in a certain way. Otherwise there will be errors. On Probooks, I still do connect power in a certain way but remove it after connecting the clip.
                                      This will not be the same with other programmers.
                                      Thatswhy, if you are not familiar how your programmer behaves with certain machines, it's always best to unsolder chip.
                                      With Dell Latitude and Lenovo Thinkpad for example, I do not connect power at all most of the times.
                                      So again, if in doubt, unsolder chip.
                                        Re: RCUnlocker
                                        Hi, did this tool work in HP 430 G6?
                                        Thanks.
                                          Re: RCUnlocker
                                          hello everyone,
                                          I have HP X Pro 612 g2, bios locked
                                          Do you have a recommendation for a suitable chip reader and writer to unlock this device?
                                          Also, is it possible to read the chip without removing it from the motherboard?
