View Single Post
Old 11-18-2011, 04:37 PM   #12
sagie
Default Re: Philips LCD TV with Sound, No Picture (model 42PFL5322/10)
Quote:
Originally Posted by retiredcaps View Post
Can you actually list all 40 readings? It matters because if 39 of them measure between 1350-1360 Ohm and 1 reads 1310 Ohm, then
1360 * 0.97 = 1319 Ohm. OR 1310 * 1.03 = 1349 Ohm.
How the 3% guideline came about by PlainBill.
http://www.badcaps.net/forum/showpos...7&postcount=18
edit: We have had cases where the measurement was off by as little as 5 Ohms to cause "2 seconds to black".
OK, as I checked the resistances a second time to write them down, I got much more consolidated readouts for some reason. This time, they were all in the range of 1300-1333 Ohms, which makes the max reading still within 3% from the min reading. I wrote all of the readings in the bottom of this message.
Are there any caps on the inverter board? If yes, what brand and series are they?
Yes, each of the 2 boards carries 5 medium sized caps and a small cap. They all appear to be in good shape visually (at least in my eyes).
I couldn't really make a brand, but here are the markings on them:
* Medium sized - 1st type
(M)105C
7(7)
1W
* Medium sized - 2nd type
(M)105C
7(7)
3W
* Small sized - 3rd type
(M)105C
One of the boards carries 5 caps of the 1st type and 1 of the 3rd. The other board carries 3 caps of the 1st type, 2 of the 2nd and 1 of the 3rd.
I think the manufacturer simply uses the 1st and 2nd types interchangeably.
I've also attached some photos to show the one of the boards and a few of the caps.
Transformer secondary windings readouts
1st board
1.1: 1312
1.2: 1306
2.1: 1327
2.2: 1317
3.1: 1319
3.2: 1316
4.1: 1311
4.2: 1308
5.1: 1317
5.2: 1318
6.1: 1332
6.2: 1326
7.1: 1310
7.2: 1306
8.1: 1307
8.2: 1300
9.1: 1317
9.2: 1312
10.1: 1306
10.2: 1300
2nd board
1.1: 1333
1.2: 1327
2.1: 1325
2.2: 1317
3.1: 1317
3.2: 1311
4.1: 1312
4.2: 1306
5.1: 1324
5.2: 1318
6.1: 1334
6.2: 1329
7.1: 1330
7.2: 1328
8.1: 1330
8.2: 1326
9.1: 1327
9.2: 1321
10.1: 1331
10.2: 1333
sagie is offline   Reply With Quote
