i need a replacement -compatible- IT8586E LENOVO
    i seek a compatible- IT8586E LENOVO
    LENOVO G50-70
    Re: i need a replacement -compatible- IT8586E LENOVO
    http://www.ebay.com/itm/Brand-New-IT...-/200993787483
      Hi there seeking a compatible- IT8586E LENOVO as well
      but for LENOVO G50-80..
      Need to ask if someone tried one of those vanilla no branded
      chips to re-program them with EC bios and that worked ?
      Paul
        You can follow two ways to change IT8586E. you can plug in the it8586e chip programmatically. or you can program it after plugging in with Svod programmer.
        I'm not happy to be so strong. because it's not humanly
          thanks for the promptly reply..
          I have a RT809F (w/ extension PB board and cable..)
          I can save the old EC and program a new one with
          that .. although I have been just "buying" pre programmed
          chips for the price so far..
          But that is not best solution.
          There are a bunch of vanilla chips (not branded LENOVO)
          and.. my doubt is *IF* I can just put one there and
          re-program the chip hoping for the better...
          Paul
            As long as the chip number is IT8586E, it works after programming. have replaced many many chips with success.
              Thanks a lot... I was determined to order
              a bunch of vanilla batch to try them myself..
              I will now certainly ditch those branded ones..
              and try to use the normal chips..
              Can not figure out why LENOVO did that..
              But they fail at miserable rate...
              thanx
              Paul
                Where to get preprogrammed IT8586E for Lenovo E460 NM-A551?
