Sony KLV32U300A starts up then shuts down
    Sony KLV32U300A starts up then shuts down with ared led blinking twice with a pause then again the same over,ould someone pls give advice on where to lookfor rhe error
    Re: Sony KLV32U300A starts up then shuts down
    Are you certain it's KLV32U300A and not KLV-32V300A
    The led fault code for KLV-32V300A is attached
      Thanks Dick,it is definitely klv32u300a
        And thanks for your input,much appreciated
          Can you post nice sharp photo's of the circuit boards
          Have you taken any voltage readings?
            Try test number 3 below, be sure to post the pin label/description, number and voltage.
              Service manual.
                Hi Dick no i hav'nt checked the voltages yet and i will post pics of the circuit boards,yesterday i switche the tv on and it actually came on for 5 minutes and switched off automatically but after that the same on off occured again.what can you make of that
                  Does it sound like the power supply or could it be on another board
                    It's just speculation until you do the tests.
                      Thanks nomoresonys
                        Hi Dick,i checked voltages on standby and all seem ok but when i removed one plug from power supply going to the main board then green light stays on which indicates that the fault is on main board but the led flashes 2 times still which according to the chart of blinking codes should indicate that the psu is the culprit,how do i post pics of the boards on here
                          Post pictures by clicking on "Go Advanced" and then I add them one at a time.
                            Hi Dick i did go on advanced and added the attachments but how do i post them,when i add attachments on email i have no problem but on here i just dont seem to get it done
                              RJ gives an explanation on how to add attachments
                              https://www.badcaps.net/forum/showpo...18&postcount=4
                                Sorry it looks like i cant add attachments yet it states invalid post
                                    Ok i finally managed to attach the psu and main board
                                      Can you give the voltages read on CN201, CN202 & CN203
                                      eg
                                      CN201
                                      Pin 1 GND
                                      Pin 2 GND
                                      Pin 3 PWR_6V = xxV
                                      Pin 4 PWR_6V = xxV
                                      Pin 5 GND
                                      etc for all pins
                                        CN201 Pin 1=GND 2=GND 3=5.63V 4=5.83V 5=GND 6=GND 7=5V 8=5V 9=GND 10=GND 11=14.60V 12=14.60V 13=GND 14=32V
                                        CN202 Pin 1=0.2V 2=0V 3=4.1V 4=GND 5=GND 6=GND 7=4.1V 8=4.1V
                                        CN203 Pins 1-5=0V And 6-10=24V
