HP Prodesk 400 g5 Desktop mini
    need working bios for this unit. thanks in advance
    Re: HP Prodesk 400 g5 Desktop mini
    post the original bios
      here it is
        here it is
        to understand that you want the bios unlocked ?? or the bios is corrupt ???
          bios corrupt sir.
            bios corrupt sir.
            HP ProDesk 400 G5 Desktop Mini PC
            Become a Badcaps supporter
            Thanks to all supporters.
              Hp Prodesk 400 G5 Desktop Mini bios
              Hello!
              I bought recently used HP 400 G5 Desktop Mini PC and wanted to install windows. As I could see, bios has password. I did a dump of it with EEPROM programmer and backed up.
              I need to clear the pass. Very thankfull if a pro could clear it.
              Thanks in advance
                Re: Hp Prodesk 400 G5 Desktop Mini bios
                Originally posted by bz8687 View Post
                Hello!
                Thanks in advance
                try..
                  Thank you so VERY much. It works 💯. Appreciate and wish you all the best ❤️❤️❤️
                    Re: HP BIOS unlock tool
                    Hi all newbie here
                    Have a mini PC (HP ProDesk 400 G5 Desktop Mini PC) but cant get a clean read from my
                    ch341a programmer because the chip is protected, will the unlock tool work and how would I use it.
                    I can up load photos if needed
                    cheers
                      Originally posted by CAPSBOY View Post
                      Hi all newbie here
                      cheers
                      remove the chip from the board before writing or reading
                      if you don't have an adapter, stick the chip to the programmer or stick wires between the program and the chip.. use one of these programs..
                      https://www.badcaps.net/forum/showpo...6&postcount=10
                      https://www.badcaps.net/forum/showpo...04&postcount=7
                      here is a video as an example..
                      https://www.youtube.com/watch?v=DWWigscuQDY
                        Ok so I have a USB programmer hooked up but it's reading FF and not the contents of the bios chip
                          It's so weird I can't read the chip .. it will say reading then finish with only 00 or FF and I can't write to it
