Toshiba 55LF621U19 vgh avvd problem
  • liquid556
    • May 2022
    • 6
    • Bahamas
    Looking for advice concerning no picture. has back lights and sound. i have vgl -7.89. vgh low at 11.85 and no avvd voltage found, i have few other voltages marked in the pictures. Can anyone tell me which test point is avvd.
    All voltages i found are marked in the pictures. No caps were shorted, so maybe someone can point me in the right direction to help narrow the issue down
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Toshiba 55LF621U19 vgh avvd problem
    Did you try disconnecting right side?
    • liquid556
      • May 2022
      • 6
      • Bahamas
      yes. i also tried the tape method on each one
      • dskall
        • Oct 2016
        • 2905
        • usa
        If no shorts you may have a bad dc to dc IC.
        • liquid556
          • May 2022
          • 6
          • Bahamas
          alright thanks. do you know any good web site i can order tv board smds. one more question. can you verifiy which test point in the photos is suppose to be the AVVD test point.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Your vgh looks like vin, not vgh. There are no standard terminology for this.
            • liquid556
              • May 2022
              • 6
              • Bahamas
              alright. il try changing the dc to dc and see what happens.
              • dskall
                • Oct 2016
                • 2905
                • usa
                May not be bad voltages. I would check data lines first and see if you have any voltage on them.
                • liquid556
                  • May 2022
                  • 6
                  • Bahamas
                  ok. i will check those out today
                    09-06-2024, 05:27 AM
                  • delphi_firebird
                    Toshiba Qosmio X755 Charging problem
                    by delphi_firebird
                    Hello Guys,
                    I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
                    - When battery is unplugged i works without any problem.
                    - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
                    - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
                    Can you help me diagnose the problem? I have attached...
                    10-16-2023, 03:04 AM
                    09-06-2024, 05:59 AM
