need flash dump for tp link modem:TD-W8961N rev:2
    Hi
    CPU part number:MT7505N
    tnx
    Re: need flash dump for tp link modem:TD-W8961N rev:2
    http://www.tp-link.com/en/download/T....html#Firmware
      tnx stj
      i need rom or bin file.firmware is in RAS format and can not reprogram by programer.
        post a dump of the original.
        the ras file probably just has some extra junk at the ends to remove.
          Here is what it looks like walking the binary
          Code:
          DECIMAL    HEXADECIMAL   DESCRIPTION
          63643     0xF89B     ZyXEL rom-0 configuration block, name: "dbgarea", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
          63892     0xF994     ZyXEL rom-0 configuration block, name: "dbgarea", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
          85043     0x14C33     LZMA compressed data, properties: 0x5D, dictionary size: 8388608 bytes, uncompressed size: 66696 bytes
          118036    0x1CD14     Unix path: /usr/share/tabset/vt100:\
          118804    0x1D014     ZyXEL rom-0 configuration block, name: "spt.dat", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
          118824    0x1D028     ZyXEL rom-0 configuration block, name: "autoexec.net", compressed size: 25972, uncompressed size: 11886, data offset from start of block: 16
          128002    0x1F402     GIF image data, version "89a", 200 x 50
          136194    0x21402     GIF image data, version "89a", 560 x 50
          253333    0x3DD95     Neighborly text, "neighbor of your ADSL Router that will forward the packet to the destination. On the LAN, the gateway </font>e destination. On the LAN, the gateway </font>"
          349586    0x55592     Copyright string: "Copyright (c) 2001 - 2015 TP-LINK TECHNOLOGIES CO., LTD."
          386471    0x5E5A7     Copyright string: "Copyright &copy; 2015 TP-LINK Technologies Co., Ltd. All rights reserved."
          386489    0x5E5B9     TP-Link firmware header, firmware version: 17256.26992.22113, image version: " Co., Ltd. All rights reserved.", product ID: 0x6E42746E, product version: 1131375727, kernel load address: 0x72002223, kernel entry point: 0x46463939, kernel offset: 4475203, kernel length: 1347765096, rootfs offset: 1768969317, rootfs length: 2020868163, bootloader offset: 1347747908, bootloader length: 1229148245
          806847    0xC4FBF     LZMA compressed data, properties: 0x5D, dictionary size: 8388608 bytes, uncompressed size: 2853276 bytes
          It would appear to have a full rom image with a footer for the CFE and then some compressed information (bootloader?)
          Follow the white rabbit.
            That binwalk output looks like gibberish to me.
              Hi
              here is original dump
                o.k.
                the first 64k is the bootloader,
                the last 64k is the settings,
                the bit in the middle is the firmware.
                so try this one i patched together.
                  So the firmware is not a complete ROM
                  Code:
                  40960     0xA000     ZyXEL rom-0 configuration block, name: "dbgarea", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
                  49172     0xC014     ZyXEL rom-0 configuration block, name: "spt.dat", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
                  49192     0xC028     ZyXEL rom-0 configuration block, name: "autoexec.net", compressed size: 25972, uncompressed size: 11886, data offset from start of block: 16
                  129179    0x1F89B     ZyXEL rom-0 configuration block, name: "dbgarea", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
                  129428    0x1F994     ZyXEL rom-0 configuration block, name: "dbgarea", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
                  150579    0x24C33     LZMA compressed data, properties: 0x5D, dictionary size: 8388608 bytes, uncompressed size: 66696 bytes
                  183572    0x2CD14     Unix path: /usr/share/tabset/vt100:\
                  184340    0x2D014     ZyXEL rom-0 configuration block, name: "spt.dat", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
                  184360    0x2D028     ZyXEL rom-0 configuration block, name: "autoexec.net", compressed size: 25972, uncompressed size: 11886, data offset from start of block: 16
                  193538    0x2F402     GIF image data, version "89a", 200 x 50
                  201730    0x31402     GIF image data, version "89a", 560 x 50
                  318869    0x4DD95     Neighborly text, "neighbor of your ADSL Router that will forward the packet to the destination. On the LAN, the gateway </font>e destination. On the LAN, the gateway </font>"
                  415122    0x65592     Copyright string: "Copyright (c) 2001 - 2015 TP-LINK TECHNOLOGIES CO., LTD."
                  452007    0x6E5A7     Copyright string: "Copyright &copy; 2015 TP-LINK Technologies Co., Ltd. All rights reserved."
                  452025    0x6E5B9     TP-Link firmware header, firmware version: 17256.26992.22113, image version: " Co., Ltd. All rights reserved.", product ID: 0x6E42746E, product version: 1131375727, kernel load address: 0x72002223, kernel entry point: 0x46463939, kernel offset: 4475203, kernel length: 1347765096, rootfs offset: 1768969317, rootfs length: 2020868163, bootloader offset: 1347747908, bootloader length: 1229148245
                  872383    0xD4FBF     LZMA compressed data, properties: 0x5D, dictionary size: 8388608 bytes, uncompressed size: 2853276 bytes
                  2035732    0x1F1014    ZyXEL rom-0 configuration block, name: "spt.dat", compressed size: 0, uncompressed size: 0, data offset from start of block: 16
                  2035752    0x1F1028    ZyXEL rom-0 configuration block, name: "autoexec.net", compressed size: 25972, uncompressed size: 11886, data offset from start of
                    no, the one from tp-link does not include the bootloader, or the settings block.
                    the missing settings block was expected because it probably has the mac's in it.
                      tnx so much stj
                      with your file i can not login to setup(user name or password is incorrect( message)).
                      i have this problem with original rom file too.
                        so do a factory reset - it's in the manual.
                        https://cdn.badcaps-static.com/pdfs/...967fd1e04f.pdf
                          tnx all friend to help
                          rest by button did not work and by setup not impossible because i can not enter to setup.
                          here i uploaded working dump updated with last firmware.
                          tnx again stj
                            so it works now?
                              yes.every things is ok.
                                Re: need flash dump for tp link modem 8961nd v3 + w8901G v3
                                pleas I need full dump for 2 router tplink
                                file format bin
                                  please dump modeme tp-link w8901G
                                    thanks
                                        HI EVERY ONE
                                        I NEED w8961n(un) ver 4.0
                                        IS THERE ANY ONE HAS THIS ONE?>?
