LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Hello hello,
    i have here L390. Dump from bios (25Q128) was verified, patched and flashed back.
    Problem is , that i have nothing os screen - i can hear only ugly melody
    HDD was removed, tamper switch not found on mobo
    *****SOLVED******
      Thanks bro, pls upload hardware id generator
        no need ID generator
          good job man you saved us alot of trouble and money!
            Thanks it work great on X1 Carbon G1
              thank you .
              tested on x280 yoga370 x260 x270 t480
              worked .
                If you are using someone else's work,
                don't forget to thank him and quote him in your software or patch
                Soon the sharing will be dead.
                The money is easy, the research is much harder.
                Last edited by SMDFlea; 09-04-2020, 02:09 AM. Reason: Link removed,don`t give them any free advertising
                  Originally posted by Sagittarius75 View Post
                  Thanks Maxpower,
                  I have T470 Type 20JN and i was patched OK.
                  -No need to backup old bios.
                  -Patch any clean BIOS file (i was downloaded from Lenovo)
                  -Burn Patched BIN.
                  -Remove Disk and Tamper Switch Tapered
                  -Turn on and do it Maxpower instructions.
                  -Burn your Original Bios.
                  -Enter to setup disable everything Secureboot, Password, Security Chip certificates etc...)
                  -No changes of SN, HWid, MacIds, (only changed OA2 String. What is this?)
                  -Enjoy your Thinkpad.
                  Dear Maxpower,
                  I think mine power on time to show boot logo is appear long. May be bug or no? Do you know any uefi bios strings for check the first initialization time? (i wanna explain: after power button on, keyboard checking ok with her lights up and down. Then i have very long waiting time for backlight of screen. )
                  Best Regards;
                  Fatih
                  I think the problem is marked in red
                    https://www.youtube.com/watch?v=Vvvs...airandTraining
                    The Zip file is protected by password
                      any one help my how to use this tool lenovo_autopatcher_0.2
                        there is already everything you need on the forum,
                        no need to look elsewhere.
                        just to point out that some come looking here but are not grateful .
                        The least thing is to share on the forum where the info was collected.
                        I don't have the password and I don't need it.
                        I can't see anywhere or marked there, thanks Badcaps forum or Knucklegrumble
                        We should all thank Allservice, from whom the patch was stolen.
                        Even if some say they did theirs.
                        The first to find the solution, it is them
                          Well said.
                            I have downloaded it, but it dose not work as in video, why ?
                              Thank you Maxpower3 for bringing those links to my attention, and thanks for pointing out some very important points.
                              As I stated in the first post, I developed the automation script, but the credits go to all the users on the forum that reverse engineered Allservice's dxe drivers.
                              When I posted this script I knew it would be downloaded, ripped off, likely rebranded, and used for profit. I don't like it, because I believe in open source and its community, but I expected it.
                              It is my gift back to the community from which I have learned something new.
                              So, it's all good.
                              Keep learning, and pass it forward.
                                hello guys, i'm trying to use the script but i'm getting this error, i did install python 3.8 , and i'm using w7
                                What am i doing wrong?
                                  rename your bios to 1.BIN
                                  autopatch.cmd 1.bin
                                  GOOOD LUCK
                                    Add Python exe to your windows path.
                                    If you don't know how to do it copy and paste the previous like I wrote into Google. There are maybe 300,000 articles explaining how to do it.
                                      i copied the whole python program to that folder and it worked.
                                      However the resulted patch did not work, the laptop did not post, there was no image on the screen. I ended up using a patch made for a different l480 and that worked
                                        What model is it?
                                          the patch must clean Nvram because with python 2.xx it doesn't work, you need python 3.xx.
                                          patch result ok but black screen
