CMOS battery life
    CMOS battery life
    Just this:
    What is the average lifetime of a classic coin battery used in today's computers for maintaining BIOS settings?
    And another one : If the battery is placed in the mobo and the mobo is not used for let's say 10, it's surely depleted, right? To be more precise, in what time does the socketed battery dry out while the motherboard has never been turned on?
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    Re: CMOS battery life
    Not used for 10 what?
    Depends on use...
    On modern boards the CMOS battery is bypassed any time +5vstb is available.
    There is no drain on it during that time.
    Mann-Made Global Warming.
    - Dr Seuss
      10 years Sorry for that.
      Just wanna know if a board left 10 years of no use, no AC plug, no nothing, has the battery still working...
        And no, they are not rechargeable batteries.
        I took out an old PII/PIII BX board the other day to test some ECC PC100 RAM.
        It probably hasn't been used in 5+ years and the battery was still working.
        Of course the cheap Chinese variety probably doesn't last that long.
        - Dr Seuss
          And is it possible that the battery may show 0.01v on a multimeter after 10 years?
            Yes but that's not enough voltage to 'hold up' the CMOS.
            - Dr Seuss
              Right, that's clear. Just wanna know the numbers...So PCBONEZ, you claim that it depends on the battery manufacturer, rite? Interesting, thought at least batteries, which tend to explode when handled inappropriately, are manufactured with safety provided to the consumers...
                the coin cell inside the "dallas module" on my 486DX33 board still has 2.97V
                and it's far older than 10years..
                  I have several Nintendo NES games with coin batteries in them still good after 25 years.
                    I guess the old saying "your mileage may vary" applies. I replace mine about every 4-5 years or so and on all used motherboards I aquire when I aquire them. Its all trivial since CR2032's and CR2025's can easily be found at most discount retailers for a couple bucks each.
                      Would it make ANY difference if the OP's ( Shodan486) board had the cmos jumper in the OFF position?
                      As I understand it, all regular lithium etc cells have a limited lifespan. Thankfully they're not expensive to replace. I'd never throw a board for the lack of one!
                      it's Michael Hockley actually... my parents have a sense of humor.
                        Jumper simply shorts the + and - together momentarily [through a resistor so it doesn't fry the battery.]
                        Leaving the jumper off would have no ill effects.
                        Leaving it in the reset position for a while would eventually drain the battery.
                        I usually just remove the battery instead of fooling with the jumper.
                        - Dr Seuss
                          PCBONEZ, can you please give us an idea of basic BIOS circuit, I mean NOT the circuit inside the BIOS, but the circuit behind the BIOS system on a motherboard. Some kinda diagram and its basic components.
                            I don't know that one. Never traced one out.
                            I only know how the BIOS chip is powered.
                            - Dr Seuss
                              One thing that interests me, its your profile (About Me page) .. you are interested in chasing women.. and that's the special science LOL
                                Not so much anymore.
                                The problem is getting away after you catch one.
                                - Dr Seuss
                                  You definitley can get 10+ years out of them with normal use.
                                    Which, woman or batteries? ..............
                                    Dave.
                                      Dave.
                                      Depends how hard you use them.....
                                        10 years seems pushing it for a CR2032...
                                        Why worry anyway? Quick test with DMM and if it doesn't work get a new one... If you don't have a DMM use an LED. Works perfect for testing them. It should glow brightly!
                                        -David VanHorn
