Lenovo v110-15isk usb ports - Schematic
    HI ALL
    Does anyone has schematic for that model.
    usb ports are not working
    Re: Lenovo v110-15isk usb ports
    Untill schematic verify 5V is present. Also with laptop off verify Data + and data - with diode mode and red tester to ground. See if you have something.
    Also try with a live linux.
      THANKS FOR YOUR REPLY
      I have notice that U3601 54B1K (or 5481k) IS GETTING VERY HOT.
      Pins 1,2 i get nothing.
      Pins 3,4 i get 3.3v
      Pin 5 i get 5V.
      i tried to find ic pin diagram but i couldn't.
      i believe that pin 5 is the input (vcc) and pins 1,2 that are connected together
      are the outputs.
      what to you think!
      thanks
        Upload a photo with it
          image uploaded
          if i can not find such a part what options do i have
            Re: Lenovo v110-15isk usb ports - Schematic
            U3601 = G524B1T11U .The motherboard schematic is available on a few paid sites.
            EDIT: G524 Datasheet https://cdn.badcaps-static.com/pdfs/...41e690a0ad.pdf
              I found the problem.
              there was a short capacitor near battery on the other side. there ware 2 capacitors in parallel and one of them was short.
              now usb ports are working
              thanks for your help.
                exactly the same problem , can you identify them please?
