Anyone Have 820-00850 schematic?
  • ibrahim03
    • Oct 2015
    • 142
    • egypt
    Re: Anyone Have 820-00850 schematic?
    Originally posted by reverendalc
    here you go
    doesn't appear to be accurate when looking at the board though.
    thank you for sharing
    • jackycan
      • May 2019
      • 3
      • singapore
      thanks you very much
      • vebble
        • Jan 2011
        • 6
        Thank you dude..
        • crowntoy99
          • Oct 2012
          • 264
          • india
          thank you
          • SSS7
            • Mar 2018
            • 11
            here you go
            Much appreciated!!!
            • guzq
              • May 2017
              • 54
              • Indonesia
              #26
              here you go
              Terima Kasih
              • phoeaung2
                • May 2020
                • Myanmar
                #27
                Thanks You Very much.
                • siroos_tz
                  • Feb 2014
                  • 119
                  • the UK
                  #28
                  here you go
                  Thanks a lot.
                  • afelix
                    • May 2020
                    • 3
                    Does this schematic work for the a 1989 EMC 3214 model?
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      #30
                      The schematics is for 820-00850 board. If that's what your board is then yes.
                      (A1989 should only have 820-00850 boards though)
                      • afelix
                        • May 2020
                        • 3
                        Thank you so much!
                        • neper
                          • Mar 2016
                          • 12
                          • usa
                          #32
                          Thank sssssss...
                          • tek365
                            Big Dumb Goof
                            • Mar 2017
                            • 3
                            this could be good! Schematic, Boardview and BIOS for 820-00850-A
                            • quezon
                              • Dec 2015
                              • 70
                              • Philippines
                              #34
                              lots of thanks
                              • deserthermit
                                • Nov 2019
                                • 10
                                • sweden
                                #35
                                thank you a lot
                                • neper
                                  • Mar 2016
                                  • 12
                                  • usa
                                  #36
                                  Thankssss everyone
                                  • schemu
                                    • Feb 2017
                                    • USSR
                                    #37
                                    Thanks a lot!
                                    • ibrahimkhanbd
                                      • Jun 2019
                                      • 4
                                      • Bangladesh
                                      #38
                                      thanks master
                                      • nnnuuummm1
                                        • Feb 2017
                                        • 13
                                        • thai
                                        #39
                                        thanl you
                                        • zippylin
                                          • Nov 2020
                                          • 15
                                          • us
                                          #40
                                          thank you
                                          • knk2729
                                            dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
                                            by knk2729
                                            06-23-2025, 07:09 PM
                                          • Ven
                                            Dynabook Satellite Pro L40-G-102 Schematic Needed
                                            by Ven
                                            Dynabook Satellite Pro L40-G-102 Schematic Needed.
                                            02-24-2025, 06:21 AM
                                          • re-atari
                                            Gigabyte GA-H110-D3A schematic/boardview needed
                                            by re-atari
                                            Hello all,
                                            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                            02-24-2025, 06:45 PM
                                          • camisao
                                            MSI GF63 12UDX-234XPT - MS-16R81 VER:2.0 - Schematic needed
                                            by camisao
                                            I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
                                            I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
                                            Now it doesn't start. 😏
                                            I've looked for burned parts but found none.
                                            The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
                                            I need the schematic to try to understand where there the problem may be or if it is repairable.
                                            Thanks!...
                                            12-02-2024, 05:30 AM
                                          • Gau_saha
                                            Schematic needed GA-H61M-S REV1.1
                                            by Gau_saha
                                            Sir ,
                                            I need the schematic of h61m-s rev1.1 gigabyte motherboard.
                                            Recently this board came to me for repair but could not find its schematic .
                                            The problem of this board is no display but the board has a power on it .Processor is not heating .
                                            For preliminary investigation i changed vga cable ,ram and processor but the same issue persist.
                                            Whenever i switch on the motherboard monitor says NO SIGNAL .
                                            The board is almost new .No sign of corrosion on the board seen .
                                            10-16-2024, 08:48 AM
