Hi this tv was fine until the owner moved to another address,
it comes on in sby with 3 blinks and psu wont start up .
tried a power on reset by holding down power on button on rear of tv and applying mains no luck
first inspected for damage dry joints or loose foils no joy
checked psu volts ,the 12v and 24v supplies should be switched on by the main board no volts
i read on the net that the micro on some later philips may need a reflow ,removed psu checked all caps with esr meter all ok
removed main board
and heatsink on micro
heated to 300 deg for 2 mins with solder station ,
let it cool and no change
anyone had experience on these oled philips ?
removed main board
