View Single Post
Old 07-07-2020, 11:17 AM   #10
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I'm a: Professional Tech
Default Re: Diagnostic card suggestion?
Then I am not really sure why you would need or want a diagnostic card(s) which represent a considerable downgrade over the test gear you already have. But if they are a must have for you then the one you have listed is cheap enough and probably as good as anything else on the market, buy it, play with it and then realise why they are mostly redundant. If there are any specific repair queries you have then post them up on the forum as these places are an invaluable source of information.
The other thing you might want to add is a logic analyser, again many of the data lines operate above the bandwidth of the cheaper logic analysers, that said I find one useful for the work I do with vintage computer equipment, you can of course use am oscilloscope as a partial substitute for an analyser to look at two or four data lines at a time.
llonen is offline   Reply With Quote
