Vizio M501D-A2R
    Vizio M501D-A2R
    Having a convergence type issue.... when the screen jumps (tried to upload video, but issue has arisen.) there is blue and red image copies that outline the original image detail. Anyone seen anything like this? this is similar to what im experiencing on this set except its the entire screen, not any one section:
    https://www.youtube.com/watch?v=OpMo6JzBYKs
    Re: Vizio M501D-A2R
    Side tab Gate drive issue on that section of the panel. You can try cleaning and reseating the cables between T-CON board and the panel first, if that does not fix it then you may need to try taped -off method on the ribbon cables..
      Re: Vizio M501D-A2R
      hey, thanks budm. i also entertained the thought of it being a tab/cof issue as well. what gets me though is its the entire image across the display...not just a particular section. Is this still caused by one tab you think? also, it is not a constant issue....dont know if thats a difference or not, it pulses every 5 secs or so...fine, blue and red artifact image, fine, blue and red....yada yada
        Re: Vizio M501D-A2R
        See training manual. Panel is failing.
          Re: Vizio M501D-A2R
          very helpful...thank you. adding this to my database of knowledge.
            Re: Vizio M501D-A2R
            Panel has failed. I am working on the same tv now and has the same problem. Interestingly, I put the screen in a 50" LG tv (LN series) to double check the double imaging and the results were the same. Vizio Tv is selling for parts
              Re: Vizio M501D-A2R
              "Tape cutoff" method to try as suggested: https://www.youtube.com/watch?v=j7vl7-vZEL8
                Re: Vizio M501D-A2R
                yes, ty for the link. i have been studying this method and asked in anothers post for more info or links. i am interested in knowing what exactly is being blocked here? which signals?
                  Re: Vizio M501D-A2R
                  Well the BAD ones of course.
                    Re: Vizio M501D-A2R
                    right on... i guess thats what counts. My craving for knowledge wont let me stop there though... ill keep searching in my off time for the answers....to bad i dont understand hindi...these guys seem to have it figured out to the letter. any good reading sources is always appreciated. cheers
