about TL866II PLUS ERROR
    am trying to install TL866II PLUS in my computer, but am getting config file writing error, how do i fix it on window 8
    Re: about TL866II PLUS ERROR
    you probably need to be admin for the install
    what version are you using? the current latest is 10.11
    http://forums.xgecu.com/viewthread.p...1&extra=#pid23
      Yep, you need to have admin privileges on Windows to install the software.
      Thanks for the Link, I should be updating mine as well. I guess might as well get the RT809h updated too.
        Yes am having the latest 10.1 , at first I didn't install through admin, but I later tried to install through admin same, do I need to uninstall the first one?
          not sure.
            I just reinstalled now in another system that has window 7 through Admin, but is saying ( config file writing error!
            Installation directory does not have write permission.
            Please modify the installation directory attribute to allow to be written.)
              I opened through admin and I didn't get the error again, on the xgecu forum a new update 10.13 released today for T56 and TL 866ll plus
                Can TL 866 ll plus and RT809F use the same TSOP 48 adopter socket? Because I see in the update that TL 866 ll plus does NAND flash
                  probably not, but you can try
                    some sockets are interchangeable others are not.
                      forgot to mention, that once the new program is installed, you have to flash the tl866 too.
                        how to flash bios with this tl866ll plus any guide
                          it is inside a new updated software. once the software runs, you have to flash the TL866
                            I tried to flash 25QJVSIQ after flashing the problem remain the same. The main board TP. RD8530. PB 816 . Is a china tv. Can someone please show me screen shoot of the TL 866ll plus I want to know if after installing the software there is settings to make before use. Because I flashed the ic and I saw the yellow light blinking while is flashing,
                              The tv is stuck on red light,
                                I checked the vcore 1.2 and 5v all present
                                  is your computer 32 or 64 bit?
                                  try uninstalling the old software, download a fresh copy then install the software on C:\Program Files (x86)\TL866
                                    system type 32 bit operating system, x64 based processor
                                    this is it
                                      try it on a 64bit windows installation.
                                        the software works fine on 64bit Linux with wine btw.
