Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Originally posted by cheeky2 View Post
    Thanks Lotas for looking I have just tried it and unfortunately it doesn't update just like the copy I have (from a German forum a while back).
    I suspect that this maybe be as a result of regional variations to the software that Toshiba implemented.
    If I find a solution or the software I will update it here.
    A schoolboy error I made!
    I bought another board for the TV which even had an earlier version of software on it, so updated the firmware up to 2.1.77.0 using the method of just plugging the usb formated with fat and which upgraded fine.
    Then tried upgrading to the latest 2.1.77.2 . So decided to get the timer out to time the 10seconds wait for releasing the buttons (THIS IS CRITICAL OTHERWISE IT WILL NOT UPDATE ) and the purchased board started to update after about 5 seconds or so.
    So tried with the original board in the TV and first attempt failed after waiting 10seconds. So tried it again this time waiting slightly more than 10seconds (around 11-12seconds before releasing the buttons). I was almost about to give up on it after about 15-20 seconds waiting and then the two leds lit up and started the upgrade process
    So my fault was that I was impatient in waiting the 10 seconds or so after pressing the two buttons and releasing them. then decided that it wasn't going to upgrade but it did after a little wait.
    So pleased to say it was resolved and now will sell the updated board back on ebay for some profit As these TV's rarely get updated and the firmware from Toshiba has been withdrawn.
      Hello !! i am looking for the DUMP File (.BIN) for Samsung UN60H7150 . Thank you
        Hi
        Telefunken
        Model No:48TF6520 48''
        S/N:7867819 700147
        PNL:23407779
        VBAZ:20273463
        Firmware Please ?
          Originally posted by kasper_sky View Post
          Hi
          Telefunken
          S/N:7867819 700147
          PNL:23407779
          VBAZ:20273463
          Firmware Please ?
          17MB211 : https://yadi.sk/d/H6eiyORxXr_jjQ
          https://www.badcaps.net
            Originally posted by Denis J View Post
            hello LOTAS,
            I flashed the U10 and u12 eproms with the 17MB82-1A software (EN25q64; BIN ET en25q16; BIN) that you generously provided me and then I put the USB key with the vestel 17mb82-1A Recovery software USB program. When switching on the television, the LEDs of the television and of the USB key flashed quickly and at the same speed. A few minutes later the led of the USB key changed to fixed and the led of the television continued to flash more slowly and the TV still does not start. Do you have a solution for my problem.
            Thank you
            wrong panel files can cause this fault. write panel code (ves...)
              Hi , im looking a bin dump a LG 24MT48DF-PZ
              eeprom mx25L8035E
                Originally posted by mi16rs View Post
                hi , im looking a bin dump a lg 24mt48df-pz
                eeprom mx25l8035e
                thanks
                lg 24mt48df-pz
                  Originally posted by Plaf70 View Post
                  Finally find it.
                  good morning friend thank you very much for sharing the firmware of this TV
                    Looking for a dump for a Grundig GU37FHD1080
                    screen: T370HW03 VD
                    Main Board: T.MSD306.8B 10305
                    Flash ic: U10
                    Thanks in advance for any help
                      screen: T370HW03 VD
                      Flash ic: U10
                      Put your non-working firmware here.
                      I'll try to fix it.
                        I'll try to fix it.
                        Thanks The TV is at a remote site so it may take a while to get the data from the flash ic and upload it here.
                          Ok.
                            lg 24mt48df-pz
                            Thanks a lot mate. all Ok
                              Fhd
                                Looking for a dump from a LG 19LG3000 television or a Hitachi 19LD4550u they use the same main board and screen just use different remote controls
                                screen: M190A-L0A
                                Main Board: 715T3009-2 VER:A
                                Flash ic: U404 MXIC3205D 16pin
                                Attached is a 22LG3000 dump which works but reduced image on the whole of the screen, which is why I require the 19inch version.
                                So would appreciate anyone with a suitable 4mb dump from the TV.
                                  I'm looking for a firmware/ software for this TV, it is stuck on boot logo and reboots every few seconds, I think before starting android.
                                  Hitachi 43HAE4251
                                  17MB171
                                  VES430UNDH-N2-N45
                                  hope someone could help, thanks.
                                    Managed to find a youtube video which Italian guy had the files who kindly sent them to me this afternoon.
                                    This is for the LG 19LG3000 which I have used in Hitachi 19LD4550U (as this model is quite rare). Bear in mind you will need to change the remote control if you have a Hitachi remote to a LG remote control.
                                    screen: M190A-L0A
                                    The dump has resolved the issues with the TV ie remote control not responding and side control buttons not operational!
                                      Hitachi 49hg6w69 i h
                                      Hallo to everyone,
                                      my TV set is booting twice, showing logo "inspire the next" and then goes to ST/BY. Not starting. (Happened after 1st use of Amazon Fire Stick).
                                      LCD panel VES490QNEL-2D-U01 and board are VESTEL (17MB120).
                                      I suppose i have a corrupted FW. It could be?
                                      The question is, where to find the right one (maybe here?) and how to properly upload it on the nand flash (hopefully without desoldering the chip).
                                      Thanks in advance for any suggestion.
                                      Lex
                                        Need dump for vizio p65-c1
                                        attached is pic of chip. from mainboard
                                          Originally posted by mallard729 View Post
                                          need dump for vizio p65-c1
                                          attached is pic of chip. From mainboard
                                          25l32063
