bricked my laptop ram from messing around too much with spdtool!
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    so i thought i could squeeze some extra speed out of my ram... i was trying it using some 2x2gb kingston hyperx so-dimm ddr2-667mhz cl4 on my dell latitude e6500 latoptop. it worked well only until when i tried flashing the modified settings on it using spdtool. laptop now beeps for bad ram... *grumble* had to add the stock 2x2gb nanya ddr2-800mhz cl6 ram back into it...
    i tried putting one hyperx module in and the other nanya module in thinking it would follow the nanya's looser timings and settings but nooo... still no boot and same old bad memory beeps.
    so i tried looking for either an spd programmer or ddr2 laptop sodimm to desktop dimm adapter but the latter only exists for ddr3 and ddr4. the ones i found on junkbay and aliexpress only actually work as a ddr2 sodimm to sodimm adapter. i wonder whats the point of those? looks pretty stupid to me... the only use i can think for it is as some kind of a sodimm riser card instead...?
    as for the former, the prices for those spd programmers can be pretty shocking! at least 40 bucks shipped for one! no way am i gonna pay 40 bucks to fix a set of modules that cost only 16 bucks...
    so anyone have any other ideas on cheap and cost-free ways to rescue my bricked hyperx sodimms? which i bricked from my own arrogance about my supposedly 1337 overclocking skillz?
    • 31260
    Re: bricked my laptop ram from messing around too much with spdtool!
    did you save a backup of the eeprom you wrote over?
      • 21981
      You can still use the smaller adapters you just need to solder a few wires to the pins so that it can be used with an SPI programmer.
      This one is a ddr3 adapter https://www.badcaps.net/forum/showpo...03&postcount=4
      The spd chips are 24c02 ,if you can find some old ram you can solder some wires to it,program it with an spd dump then solder the new one on. https://www.badcaps.net/forum/showpo...2&postcount=13
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        yea. spdtool is such that u have to dump the spd data to disk and edit it then save the modified spd data to eeprom. i saved both the original dump and modified spd data to disk. so that i can revert and redo the edit if i dont like my modification.
        • Daniel Valdez
          Samsung UN70RU7100K halfway bricked after messing with service menu
          by Daniel Valdez
          Dear All,
          FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
          12-06-2024, 06:56 PM
        • q2v5
          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
          by q2v5
          Lenovo T480s
          Model 20L8-S3TE00
          Board ET481-U10
          Chip MX25L12873F
          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
          08-15-2024, 10:40 PM
        • guizmo1967
          Cambridge Audio Azur 651A , bricked I think !!
          by guizmo1967
          *** Excuse my writing, English is not my first language ***
          I had a perfectly working amplifier but ….
          I noticed there is a PIC16F882 that control this amplifier. Since I'm familiar with those PIC microcontrollers, I made a lot of program in C for different projects throughout
          the years using those microcontrollers, I just wanted to see if I could just read this pic for keeping a backup of the firmware.
          The pic got detected fine with my programmer, but It was reading all zeros, so I'm pretty sure it is code protected. After trying...
          09-23-2025, 09:15 PM
        • Lexsmash85
          Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
          by Lexsmash85
          Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
          Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
          USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
          08-06-2025, 03:41 AM
        • studdy05
          Bricked HP Probook 450 G7 Bios questions
          by studdy05
          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
          Ive got...
          07-08-2025, 09:24 PM
