Faulty DVM
  • barry wilkins
    • Aug 2009
    • 172
    Faulty DVM
    One of my DVMs has gone faulty .
    I know why this has happened I was repairing some SMPUs ,they do have some high voltages on the 130volts and 425 volts .It has a range of 1000 volts this is why I was using this DVM .
    The high voltage has dammaged something ,it has gone noisey ( 2/3 didgits) but still seems to read .Exept it will not read diodes anymore
    If anyone could advise me about any thing I could replace .
    It has got a dual opamp on the board
    thank
    Barry Wilkins
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Faulty DVM
    Can't help without a make and model number. Clear focused pictures on the sides would help too.
    --- begin sig file ---
    --- end sig file ---
    • u666sa
      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
      by u666sa
      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
      Platform: ipa32 la-m024p rev 1b
      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
      I found a short on the other side:
      10-04-2025, 05:03 PM
    • MisterAIL
      PS5 digital / No Power / No Beep / Good power supply
      by MisterAIL
      Brought a non functionnal PS5. Apparently only a bad PSU...
      No beep, nothing.
      After some tests i found this :
      - PSU is fine (12 volts stable)
      - 12 volts line is shorted
      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
      - By the way, nothing change. No signal, no power, no beep.
      Mesuring all rails with my workbench psu (12 volts input)
      - 0.00 amp drawing
      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
      03-12-2024, 03:24 PM
    • supermattch
      HP 15dy-2021nr wont power on mystery volts
      by supermattch
      Hi everyone.
      I am diagnosing my personal laptop, because it wont power on and no leds light up.
      At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
      Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
      09-23-2025, 12:13 PM
    • Mcfeetroy
      Fishing bite alarm drains battery
      by Mcfeetroy
      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
      08-01-2025, 03:52 AM
    • BTubbs200
      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
      by BTubbs200
      Dell Latitude 5420 P137G
      Board: LA-K491P REV A01
      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
      Board seems to have no shorts, all power rails are fine and show high resistance.
      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
      01-24-2025, 08:15 PM
