Lenovo X250 not charging
  • bakre
    • 105
    • Zwolle
    Hello
    I have an Lenovo x250 laptop that is not charging, but when I change the volt from 20v to 18v is start charging normally, do any one have an idea?
    the bios is updated to last version, i have also change the battery but the same problem also.
    I have test the id charger is good and replace ic charger the same problem and replace the SMC the same problem.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo X250 not charging
    Check AD_ID voltage when powered by 20V/18V and observe the difference.
    • bakre
      • 105
      • Zwolle
      yes it is change to 1,69v with 18 volt but with 20 volt it give 1,44volt.
      i try to replace the resistor to make the id volt 1,69v when plug 20 volt but it remain not charging the same problem, the problem it is not the id charger, it is something else.
      but when power it with 18 volt the 3,3v it rise to 3,7v, and when i power it with 20v the 3,3v it remain 3,3v.
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • andrhouseolly
        Lenovo X240 - motherboard replacement for X250, no image.
        by andrhouseolly
        Friends. I beg you to help me in this situation.
        Lenovo X240 with a video problem. Native Intel drivers are not installed,
        after installation, a black screen. It works with the standard Microsoft driver.
        Understanding that there are problems with the video core,
        I ordered a motherboard from Lenovo X250.
        The laptop turns on, starts up, there is no image on the internal display.
        The image is output to the external monitor.
        I ordered another motherboard from Lenovo X250.
        07-12-2024, 03:02 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • dimis1975
        Macbook A1466 2014 not charging with macsafe 2 charger
        by dimis1975
        I have a macboook air a1466 that stopped charging the battery.
        BAT PINS: with or without ADAPTER IN
        1- GND
        2- GND
        3- GND
        4-0V sense pin
        5-3.42V
        6-3.42V
        7- 8.4V
        8- 8.4V
        9- 8.4V
        AC Adapter plugged in: after a lot of of hours some times start charging
        No BAT Connected- Green to Orange
        AC Adapter plugged in: BAT Connected- no light
        The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
        Any ideas what’s wrong please?...
        08-05-2025, 03:43 AM
